Problem fitting a 15x10 inch rim on an E Body. #1596805
03/22/14 05:52 PM
03/22/14 05:52 PM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
I am trying to go with a larger rear wheel and tire on my 1970 Barracuda. I have a Dana 60 (Strange S60) with the B Body Brackets and off set rear springs. I was planning on using Vintiques Rally wheels 15 x 10 with a 5.5 inch offset. Currently I have a 15 x 8 with a 4.5 offset. I got the wheels but the fitment looks wrong (fender side)....
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596806
03/22/14 08:45 PM
03/22/14 08:45 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Tape a large piece of cardboard to the floor under the brake hub and plumb bob all the key points onto it. The leaf spring line, wheel well lip, hub face, etc. Then you can easily measure all the opening you have available and the backspace that will work.
I have 10" Cragars with 28x12 MTs in the wheel wells of my Cuda.
P.S. I have a '66 B body 8 3/4 in the car.
Master, again and still
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596807
03/22/14 08:52 PM
03/22/14 08:52 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Is your rear width E or B body width?
It'll work either way. I run them on a challenger with E body width rear end. I had to clearance the inside fender flange on one side to clear the sidewall of the tire during spirited driving.
Next time I'm using a B body width rear end and it would be perfect with 15X10" wheels with 5.5" BS.
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: Challenger 1] #1596808
03/22/14 09:21 PM
03/22/14 09:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It'll work either way. I run them on a challenger with E body width rear end. I had to clearance the inside fender flange to clear the sidewall of the tire during spirited driving.
Me too, but they do fit.
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: jbc426] #1596809
03/22/14 10:58 PM
03/22/14 10:58 PM
GEORGIA
barracuda7199 Offline
GEORGIA
68 to 70 B body rear end and dr diff relocators will fit a 15x10 with 5.5" backspace. That's what's under my car with a 325/50 M/T drag radial. Had to roll the lips to fit that much tire, but that doesn't bother me with my junk.
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: barracuda7199] #1596810
03/23/14 01:19 AM
03/23/14 01:19 AM
scrag Offline OP
scrag  Offline OP
I have the B Body rear with Dr. Diff offets as well....from the outer lip of my rim I can barely fit a yardstick to the fender lip....
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596811
03/23/14 01:20 AM
03/23/14 01:20 AM
scrag Offline OP
scrag  Offline OP
plenty of inner clearance
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596812
03/23/14 01:31 AM
03/23/14 01:31 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
What year is the B-body rear?
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: sixpack4spd] #1596813
03/23/14 01:35 AM
03/23/14 01:35 AM
scrag Offline OP
scrag  Offline OP
It was built by Strange so it is an S60.
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596814
03/23/14 01:44 AM
03/23/14 01:44 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Are the wheels 15x10 with 5.5" backspacing?
That appears to be a lot of inside clearance but that might change depending on the tire size.
I'm planning on installing a 1970 B body rear under the wife's Challenger.
The rims for the rear I bought many many years ago and are custom built Torque Thrusts 15x10" with 5.75" back spacing.
The extra 1/4" of back spacing should help keep the tire away from inside of the quarter panels.
I have 325/50-15 BFG drag radials for the car.
I was anticipating tinking with different thickness wheel spacers to get the rims perfectly centered, I would love to have all the inside clearance your picture shows.
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: KillerBee] #1596815
03/23/14 01:54 AM
03/23/14 01:54 AM
scrag Offline OP
scrag  Offline OP
Yes the Rim is a 15 x 10 with 5.5" clearance. I am looking through my Strange Engineering receipt the axles were cut to 29 3/8 and 30 3/4....not sure what a B Body is
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596816
03/23/14 02:14 AM
03/23/14 02:14 AM
smyrna,tn
draginmopars Offline
smyrna,tn
our 68 Satellite
Moser Dana 60 (spool)
stock width
28 1/2
29 7/8
10" rallye
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: draginmopars] #1596817
03/23/14 02:21 AM
03/23/14 02:21 AM
scrag Offline OP
scrag  Offline OP
Thanks for that info.....that would explain why it is too tight....
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596818
03/23/14 02:28 AM
03/23/14 02:28 AM
smyrna,tn
smyrna,tn
I don't know the specs for an E body
Maybe it was built to the E-body spec ?
if you look at the posted pic
you may notice the weighted strings hanging at the inner tires
drop some string down from the wheel flange, to the floor
to get the full width of that rear end
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: draginmopars] #1596819
03/23/14 02:32 AM
03/23/14 02:32 AM
scrag Offline OP
scrag  Offline OP
I think the E Body Spec is 30 and 31 but I am not positive...and since the rear is 3 years old...lol Funny part is that they put the correct B Body pads on it as it matched the offset kit just fine. I appreciate the help from everyone....I will have to stick to a 8" rim with as big a tire as I can fit.
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596820
03/23/14 02:46 AM
03/23/14 02:46 AM
smyrna,tn
smyrna,tn
Yea,when we put the moser rear under the rampage (2010)
the Sales person at that time
asked if I wanted the ford/dodge housing ends on the rear.
I didn't think anything about it until
we went to set the 8 3/4 alum carrier into a 9" (ford)housing flange
Ha-Ha Racin
Havin Fun 101
Howard
71 360 Dart Swinger
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596821
03/23/14 11:23 AM
03/23/14 11:23 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
See if your axles have extra spline length and can be shortened some more. Many times aftermarket axles can be cut down another inch.
Looks like you have the 10" wheels and that is your goal, I'd see if I could cold cut another 1" off each axle and then have the housing shortened 2".
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: B5 Bee] #1596822
03/23/14 11:44 AM
03/23/14 11:44 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Or return your rims and get 6.5" backspacing. Or have the backspacing changed on your rims to 6.5".
You rims will not look at deep when viewed from the side though. If you are running rallye rims, they will end up looking just like a typical 15x8 with 4.5 backspacing.
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: autoxcuda] #1596823
03/23/14 07:50 PM
03/23/14 07:50 PM
scrag Offline OP
scrag  Offline OP
i am going to call on that tomorrow to see if they will do a custom backspacing in this rim (it is not listed in their catalog. I know I can put a 295/65/15 on an 8 inch rim - at least the manufacture lists that I can (MT Drag Radial) just wondering how much further out the tire will be on my current rim 15x8 4.5 Backspacing with regards to the fender....
Re: Problem fitting a 15x10 inch rim on an E Body. [Re: scrag] #1596824
03/23/14 09:22 PM
03/23/14 09:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
So you've got the B body rear perches and offset shackles...It looks like you've got a bunch of room to go on the inside....At this point would'nt getting the proper backspacing for the 10 inch rim give you what you were shooting for from the beginning ??? Why go back to an 8 inch rim now ???
