E body rear spring hanger mount #1596665
03/22/14 02:47 PM
03/22/14 02:47 PM
Rescue CA.
joes68340s Offline OP
Rescue CA.
Does anyone or can anyone post a picture of a 1970 E body rear spring hanger. The shackle and frame mount. I cant find what it is supposed to look like stock. I have offset shackles on mine but the front spring eye bracket is stock. I dont know what has been done till I see a stock rear shackle and mount. Thanks
Re: E body rear spring hanger mount [Re: joes68340s] #1596666
03/22/14 02:53 PM
03/22/14 02:53 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Great vendor and good reference pictures?
http://arengineering.com/home-page/spring-hangers/
Re: E body rear spring hanger mount [Re: brads70] #1596667
03/22/14 03:40 PM
03/22/14 03:40 PM
Rescue CA.
Rescue CA.
Really need a photo of stock location hanger.
Re: E body rear spring hanger mount [Re: brads70] #1596668
03/22/14 04:12 PM
03/22/14 04:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I believe E bodies had splayed rear leafs, the front eyes were closer together than the rear hangers. Kinda like /\, but it's been over 20 years since I had an E body.
Don't be the exception.
Re: E body rear spring hanger mount [Re: Supercuda] #1596669
03/22/14 04:58 PM
03/22/14 04:58 PM
Rescue CA.
Rescue CA.
yes I need to see what stock hanger was used. I have an offset on mine And I dont know if that is correct.
Re: E body rear spring hanger mount [Re: joes68340s] #1596670
03/22/14 05:28 PM
03/22/14 05:28 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Click here:
http://chucker54.stores.yahoo.net/rearshackles.html
offset rear shackles are not factory, the straight ones are factory. Offset shackles only move things in a little.
What is your intention with this project?
Re: E body rear spring hanger mount [Re: PHJ426] #1596671
03/22/14 06:33 PM
03/22/14 06:33 PM
Rescue CA.
Rescue CA.
My intention is to try to find out what and why the offset shackle was installed for. the front spring eye bracket is not offset so I dont know why there is a rear offset. Does the stock shackle attach through the frame. Im trying to get the photo of the rear suspension on the car as seen from below. Not parts in pictures on websites. Thanks
Re: E body rear spring hanger mount [Re: joes68340s] #1596672
03/24/14 03:56 PM
03/24/14 03:56 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Yes the factory rear shackles attach through frame and theyare straight. Unless you can contact the previous owner you may never find out why there is an offset rear shackle and a standard front hanger on your car. Sometimes its unexplainable what some of these cars have gone through.
Try posting some pictures of the rear suspension and maybe we can guess what is going on but from your description I don't have any clue.
Re: E body rear spring hanger mount [Re: PHJ426] #1596673
03/24/14 06:40 PM
03/24/14 06:40 PM
Rescue CA.
Rescue CA.
Ive installed a few offset spring kits on A bodys but Ive never seen this before. It looks like there is some offset on the stock frame mounts as one side protrudes out more than the other so even though a straight shackle is used the mount is offset because of the angle the rear frame rails run. Unfortunatly the previous owner passed away and the wife isnt noligable about specifics of the car.
Re: E body rear spring hanger mount [Re: joes68340s] #1596674
03/24/14 08:54 PM
03/24/14 08:54 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Taking some pictures and posting them will probably get you more input.
Re: E body rear spring hanger mount [Re: PHJ426] #1596675
07/14/14 10:04 PM
07/14/14 10:04 PM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
are the leafs parallel or pigeon-toed? If they are straight, i bet $5 that you have a b-body axle housing in there- as to fit wider tires. Very common racer trick to use S-shackles and switch the housing. The front hanger remains stock. I should add that most also then put Super stock springs and longer front hangers in- still straight though, not offset. Pics would help.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: E body rear spring hanger mount [Re: chrisnben] #1596676
07/16/14 07:24 PM
07/16/14 07:24 PM
Rescue CA.
Rescue CA.
Thanks I will look and measure. I didn't think of that. I know it was drag raced in the late 70s. It had once been converted to a 4 spd and then switched back to the stock column shift auto.
Re: E body rear spring hanger mount [Re: joes68340s] #1596677
07/17/14 12:41 PM
07/17/14 12:41 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
You may have to take a lot of measurements to try and figure this out exactly. Since it has been a drag racer in its previous life, I'd most likely say it was to increase tire clearance. As stated earlier, the E body springs are splayed to be wider at the rear. This type of install can reduce the available space for tires by a half an inch on the rear segment. Putting offset shackles in without a corresponding offset hanger could put rear segment of the spring more parallel to the front an allow a skosh more tire. However, this has also likely put the springs into a potential binding situation, unless the spring mounting pad location hole was also opened up a bit.
The splayed mounting arrangement does tend to reduce roll induced oversteer and stabilize the handling some. To restore this would require the offset front hanger while still allowing for wide tires. However, to do this with the stock E body housing will also require moving the spring mounting pad inboard the corresponding amount.
Another alternative is to use the offset bracket/shackles and drop in a B body housing which will fall right onto the springs without moving spring pads.
With the offset shackles, their mounting point into the frame horn should not have changed. The shackles are bent to create the offset. The mounting point does not change. Returning to straight shackles should allow them to bolt right back into the stock location.
Re: E body rear spring hanger mount [Re: joes68340s] #1596678
07/19/14 03:02 PM
07/19/14 03:02 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
I haven't read the entire post but I moved my springs in .080 using the rear offset MP E body spring hangers and the A body front spring hangers. I have the OEM hangers and can measure things for ya.
I beleive (IIRC) that the A body offset front hanger is straight, but the bolts are offcenter/offset
http://www.moparts.org/Tech/Archive/rearsusp/12.html
see the clearance for the studs head?
Re: E body rear spring hanger mount [Re: UCUDANT] #1596679
07/22/14 11:21 AM
07/22/14 11:21 AM
Rescue CA.
Rescue CA.
Thanks for the replys. I have not been out to look it over again but I know the front mount is a stock style mount.
Re: E body rear spring hanger mount [Re: joes68340s] #1596680
07/26/14 12:39 PM
07/26/14 12:39 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
Those springs will be noticeably twisted if the front and rear hangers are mismatched. I once saw a Cuda someone tried it on. I think the spring pads were stock at the car I saw
