440 6 pack breather/vacuum line setup #1596643
03/22/14 01:53 PM
03/22/14 01:53 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Looking for pics of the factory correct breather and vacuum lines setup for a 70 440 6 pack with power brakes? Really need an idea of what the correct breather should be. Thanks
Re: 440 6 pack breather/vacuum line setup [Re: 70VcodeCoronetRT] #1596644
03/22/14 03:07 PM
03/22/14 03:07 PM
Indiana
P
Pentastar440 Offline
P
Indiana
6 pack setup :
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 440 6 pack breather/vacuum line setup [Re: Pentastar440] #1596645
03/22/14 07:34 PM
03/22/14 07:34 PM
Nebraska
Nebraska
Thanks!!!!! Looks like the factory breather had 2 nipples. One for bowl vent and one for the air cleaner?
Re: 440 6 pack breather/vacuum line setup [Re: 70VcodeCoronetRT] #1596646
03/22/14 09:17 PM
03/22/14 09:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bowl vent in 70 would be an emmision carb , california , normally 70 would only have a breather for the air cleaner.
Re: 440 6 pack breather/vacuum line setup [Re: JohnRR] #1596647
03/23/14 03:16 AM
03/23/14 03:16 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Mine had power brakes but pulled the booster since I had not enough vacuum for the power brakes
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 440 6 pack breather/vacuum line setup [Re: 70sixpkrt] #1596648
03/23/14 03:17 AM
03/23/14 03:17 AM
70sixpkrt Offline
70sixpkrt  Offline
4-speed
3:54 Dana
Re: 440 6 pack breather/vacuum line setup [Re: 70sixpkrt] #1596649
03/23/14 01:12 PM
03/23/14 01:12 PM
Nebraska
Nebraska
So is that the ECS breather? With the third gas tank vent nipple? I'm guessing those were for the cars with the ECS only?
Re: 440 6 pack breather/vacuum line setup [Re: 70VcodeCoronetRT] #1596650
03/23/14 02:07 PM
03/23/14 02:07 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
The 3 nipple breather was only used on California (ie ECS) 6-bbl setups (first photo)and the center carb (List R-4144A or R-4374A) had a bowl vent tube (2nd photo)
The non-California cars cars had a single nipple breather (3rd photo) and had a completely different fuel bowl on the carb (List R-4375A or R-4376A) (4th photo)
Hope that helps.
Re: 440 6 pack breather/vacuum line setup [Re: RealWing] #1596651
03/23/14 02:08 PM
03/23/14 02:08 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
ECS fuel bowl
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: 440 6 pack breather/vacuum line setup [Re: RealWing] #1596652
03/23/14 02:10 PM
03/23/14 02:10 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Re: 440 6 pack breather/vacuum line setup [Re: RealWing] #1596653
03/23/14 02:12 PM
03/23/14 02:12 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Non ECS fuel bowl
Re: 440 6 pack breather/vacuum line setup [Re: RealWing] #1596654
03/23/14 02:26 PM
03/23/14 02:26 PM
Nebraska
Nebraska
Thanks, that helps a lot. Thanks again
Re: 440 6 pack breather/vacuum line setup [Re: 70sixpkrt] #1596655
03/24/14 11:32 AM
03/24/14 11:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This car has ECS ??
Re: 440 6 pack breather/vacuum line setup [Re: JohnRR] #1596656
03/24/14 11:57 PM
03/24/14 11:57 PM
70sixpkrt Offline
70sixpkrt  Offline
This car has ECS ??
Yes. Mine came with ECS.
4-speed
3:54 Dana
