? About piston top thickness #1596445
03/22/14 01:27 AM
03/22/14 01:27 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
I was given a set of 2322 trw pistons that have been milled to flat tops. I see in a speed pro catalog I have that these are shown both as doomed 12.5 to1 and also as flat tops. My ? Is what thickness would be safe after cutting them. I'm getting .200 on these pistons and when I compare other pistons in my possession the thinest I found were .300. What is a safe # for n.a. use (no nitrous)? Even some old stockers I have are .300 or more. Thanks
Re: ? About piston top thickness [Re: 3ddart] #1596446
03/22/14 02:13 AM
03/22/14 02:13 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
IMOP you don't hsve enough thicknness for that cylinder pressure.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: ? About piston top thickness [Re: hemi-itis] #1596447
03/22/14 10:26 AM
03/22/14 10:26 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
That's why I'm asking, really don't want to experience that kind of failure!
Re: ? About piston top thickness [Re: 3ddart] #1596448
03/22/14 10:31 AM
03/22/14 10:31 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
My Wiseco pistons are .205 and live @11.5:1
Yeah, it's got a smallblock.
Re: ? About piston top thickness [Re: 3ddart] #1596449
03/22/14 12:25 PM
03/22/14 12:25 PM
Guitar Jones Offline
I have run as little as .090 in a spot for the valve relief at 12.7 in an NA smallblock.
Re: ? About piston top thickness [Re: 3ddart] #1596450
03/23/14 10:35 AM
03/23/14 10:35 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
any old timers remember what the thickness was on the cut 2322 trw pistons from the catalog?
Re: ? About piston top thickness [Re: 3ddart] #1596451
03/23/14 10:49 AM
03/23/14 10:49 AM
Jerry Kathe Offline
Jerry Kathe  Offline
I don’t think there is a blanket answer for that. The old forgings are not of the same material used today in the upper end custom pistons, so watch what you are comparing to. I would be comfortable to say that the original design had quite a safety margin built in and you could go lower than that. Did you measure the deck thickness adjacent to the now removed dome area for its original thickness?
If it detonates like the pic above…thickness wont matter - lol
Re: ? About piston top thickness [Re: Jerry Kathe] #1596452
03/24/14 04:10 PM
03/24/14 04:10 PM
dogdays Offline
dogdays  Offline
It's generally accepted that 0.200" is the minimum for piston top thickness.
Some older Speed Pro (TRW) catalogs listed compression for solid dome pistons with the domes removed, which is what yours sounds like.
R.
