Page 1 of 3 1 2 3
Front spoiler for 70 Duster drag car (130mph) #1596305
03/21/14 08:12 PM
03/21/14 08:12 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
I'm looking for more front end stability at the top end (130mph). Based on what I've read, I think I should try a front spoiler. I contacted Spoilers by Randy, but he doesn't think it will hold up at that speed. Has anyone tried that one at this speed?
Is there a stronger pre-made one out there or does everybody build their own?
Re: Front spoiler for 70 Duster drag car (130mph) [Re: 440Brian] #1596306
03/21/14 08:30 PM
03/21/14 08:30 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Have you tried looking other places in the front end to gain stability? Not to destroy your thread but I don't think 130 should be too loose and require a spoiler. I think maybe there is a bigger hidden issue here. My stock front end is fine at those kind of speeds.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: 440Brian] #1596307
03/21/14 08:45 PM
03/21/14 08:45 PM
412 SB Duster Offline
May want to look at your alignment, I've been 137 with no issues with stock setup. And
Know a lot of others that have been faster.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: 440Brian] #1596308
03/21/14 08:46 PM
03/21/14 08:46 PM
Locomotion Offline
Locomotion  Offline
Do you have clearance to lower the front any? Proper front end alignment can also affect/help top end stability.
Something integrated into the bumper, straight down with a small lip facing out would help, but would involve a lot of fabricating and take away from the classic Duster look.
I built a simple, angled and reinforced aluminum plate front spoiler on my old street challenger. But that was before I ever went to the drag strip or went that fast.
It can get complicated and if it forces too much air under the hood, you could have problems keeping it on.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: Locomotion] #1596309
03/21/14 09:51 PM
03/21/14 09:51 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Check the play in the steering box
Check the welds on the steering box
check toe in with a floor jack for improper changes.
check for play in front suspension parts
Make sure front and rear tires are proper for each other.
If the front is to high try lowering but if you do so with the torsion bars check alignment again.
35 plus pounds in front tires.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Front spoiler for 70 Duster drag car (130mph) [Re: 440Brian] #1596310
03/21/14 10:01 PM
03/21/14 10:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It looks like you could lower the front 2"(re-align
after but use racing specs)
Re: Front spoiler for 70 Duster drag car (130mph) [Re: MR_P_BODY] #1596311
03/22/14 01:31 AM
03/22/14 01:31 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
That hood catches a lot of air that is pushed into the engine bay and that ads to air under the car also.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: dezduster] #1596312
03/22/14 01:39 AM
03/22/14 01:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That scoop doesnt catch that much but the grill
opening sure does.. for racing you can close the
whole grill off... it should pick up ET and MPH
Re: Front spoiler for 70 Duster drag car (130mph) [Re: MR_P_BODY] #1596313
03/22/14 03:03 AM
03/22/14 03:03 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i agree. when i fitted my cowl & blocked off my grill i picked up both et & mph with no engine work. but back to the subject, i fitted this front spoiler which definately helped pull the front down at speed, so much so that the rear was becoming twitchy at the top end. i had to fit a rear wing to control that & now my car pushes down hard & is real stable even on a slipery track.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: rebel] #1596314
03/22/14 08:07 AM
03/22/14 08:07 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Apologies to OP about the thread hi-jack.
Rebel, closing the grill off, how did that effect engine temps?
Re: Front spoiler for 70 Duster drag car (130mph) [Re: 440Brian] #1596315
03/22/14 09:25 AM
03/22/14 09:25 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We started having trouble with ours over +125...Found some issues with the front steering and tie rods...Actually had a weld 85% torn on one side that holds one of the pivot arms on...Then found the bolt that holds the linkage to the pivot was the wrong diameter and replace a couple of worn out ball cups...Now +135 and its not to bad..I would be looking at anything that allows too much movement in the linkage and the items the linkage is bolted too...
Re: Front spoiler for 70 Duster drag car (130mph) [Re: Dragula] #1596316
03/22/14 09:35 AM
03/22/14 09:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If ALL of the front end parts are right and tight I
might think about the rear of the car... the front
doesnt tend to lift(areo wise) with a heavy engine
sitting in front at those speeds... what some guys
think is the front moving can be the back.. if you
get the front end shudder its loose or bad parts
EDIT
If the car starts to dart back and forth its normally
a toe OUT issue at some point in the travel
Re: Front spoiler for 70 Duster drag car (130mph) [Re: 440Brian] #1596317
03/22/14 10:09 AM
03/22/14 10:09 AM
Q
Quicktree Offline
Quicktree  Offline
Q
yea the thing is setting way high in the front, do you have a full view pic? Like Locomotion said lower the front and possibly the whole car some.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: MR_P_BODY] #1596318
03/22/14 02:03 PM
03/22/14 02:03 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What's the rear tire pressure? That can make the car loose if it's too low, it can give the feel that the front end is loose
Re: Front spoiler for 70 Duster drag car (130mph) [Re: SpareParts] #1596319
03/22/14 02:38 PM
03/22/14 02:38 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Your car appears to sit a little high in the pic you posted.....
We had a 69' Barracuda in the early 90s with a 68' SS/AH scoop, all brand new stock front suspension pieces and steering box, with a set of Koni shocks and that car was pretty stable at 155.80 without any body modifications, spoilers, grille blocks, etc.....
Try lowering front, then check the alignment and all front end/steering components. I wouldn't think there'd be an issue at in the 130 range, but if there's a component problem somewhere, you'll feel it.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: jim sciortino] #1596320
03/22/14 03:14 PM
03/22/14 03:14 PM
PA.
"Little"John
"Little"John
PA.
Lots of guys suggested the ride height being to high and its hard to tell from your picture but it very well could be an issue. I changed out a set of super stock springs years ago on my 9 second 74 Duster as the other set had LOTS of runs on them. Well the car sat a little higher and that car was terrible to drive. I removed them that week and took them to a spring shop and had them de-arched some and the car worked great. If possible post some better side, front and rear pictures and the guys on this site will get you straightened out.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Front spoiler for 70 Duster drag car (130mph) [Re: pittsburghracer] #1596321
03/22/14 05:28 PM
03/22/14 05:28 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
My dart used to get a light feeling above 120, and it helped alot to lower the front, I also added a spoiler from a 69 camaro. The lower valance on the dart made this easy. The duster isn't the same, so the spoiler might not work.
The spoiler I used was ABS plastic, pretty flimsy itself, but I fastened the top to the valance, then ran tube supports to the bottom edge. I could putt the car forward from the spoiler, there was no deflection at high speed.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Front spoiler for 70 Duster drag car (130mph) [Re: Tig] #1596322
03/22/14 06:06 PM
03/22/14 06:06 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it didn't change it at all. my electric fan pulls sh!tloads of air thru my radiator & i can drive back to my pit after a run with ease.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: rebel] #1596323
03/22/14 06:23 PM
03/22/14 06:23 PM
gregsdart Offline
gregsdart  Offline
Check bump steer also. It looks like the front would run through the lights very high, and might be WAY off on alignment. That would cost you handling, and a chunk of ET and MPH. stock A bodys with good alignment and components are good to 130 at least. Also check caster, to see if you have any. You want all you can get.
Re: Front spoiler for 70 Duster drag car (130mph) [Re: gregsdart] #1596324
03/22/14 06:29 PM
03/22/14 06:29 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I went from 29.5 tyres to 31" and if the car got a bit of line it was quite unnerving. I fitted 1-1/2" lowering blocks and it was fine after that.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Page 1 of 3 1 2 3
