welding ???????????? chromoly to mild steel #1596243
03/21/14 04:45 PM
03/21/14 04:45 PM
ohio
all spooled up Offline OP
ohio
can u weld a chromoly part to a mild steel part with a tig welder
Re: welding ???????????? chromoly to mild steel [Re: all spooled up] #1596244
03/21/14 04:59 PM
03/21/14 04:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Yes.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: welding ???????????? chromoly to mild steel [Re: all spooled up] #1596245
03/21/14 05:02 PM
03/21/14 05:02 PM
PA.
"Little"John
"Little"John
PA.
My Daytona cage (mild steel) was upgraded from a 8.50 cert to a 7.50 cert in 2009 and 6 chromoly bars were tig welded in. The guy doing the work prefers to work with moly.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: welding ???????????? chromoly to mild steel [Re: all spooled up] #1596246
03/21/14 06:09 PM
03/21/14 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes any time you join moly to mild you have to play
it just like moly... in other words it has to be tigged
Re: welding ???????????? chromoly to mild steel [Re: MR_P_BODY] #1596247
03/21/14 06:32 PM
03/21/14 06:32 PM
sg66mopar Offline
sg66mopar  Offline
Are we talkin' cage here or just mild to Moly in general?
I've mig welded the two a few times over the years in "non critical" applications with no problems.
Just did the 7.50 upgrade on the Charger the last couple weeks and tig welded the Moly to the old mild steel cage. Proud owner of an NHRA 7.50 sticker.
Re: welding ???????????? chromoly to mild steel [Re: sg66mopar] #1596248
03/21/14 07:10 PM
03/21/14 07:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its a chassis the first joint to mild( if adding
moly HAS to be tigged .. then each joint has to be
tigged if its moly.... IF by chance you are adding
mild to moly(chassis or cage set up)the first joint
where the moly and mild connect it has to be tigged
then all the rest of the mild can be migged... if
its not a cert thing, then yes you can mig it.. but
I dont like to.... I tend to tig even mild for a nicer
looking weld
Re: welding ???????????? chromoly to mild steel [Re: MR_P_BODY] #1596249
03/21/14 07:17 PM
03/21/14 07:17 PM
ohio
ohio
its a moly rod end adapter to mild steel round tube..
Re: welding ???????????? chromoly to mild steel [Re: all spooled up] #1596250
03/21/14 07:22 PM
03/21/14 07:22 PM
sg66mopar Offline
sg66mopar  Offline
I'd definitely tig that. ER70S2 rod, in my opinion.
Re: welding ???????????? chromoly to mild steel [Re: sg66mopar] #1596251
03/21/14 07:31 PM
03/21/14 07:31 PM
ohio
ohio
thanks
Re: welding ???????????? chromoly to mild steel [Re: all spooled up] #1596252
03/21/14 07:48 PM
03/21/14 07:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Still has to be tigged(in my opinion for the strongest
joint).. the er70 is fine... also on tube adapters
you should drill a hole back about half way on it
through the tube and puddle weld it closed for a
proper way to do it... I do that all the time(if
you ever had it checked that is required)
EDIT
depending on the size of the insert I usually drill
a 3/16 or a 1/4 hole to fill
Re: welding ???????????? chromoly to mild steel [Re: MR_P_BODY] #1596253
03/22/14 01:33 AM
03/22/14 01:33 AM
ohio
ohio
thanks mike
Re: welding ???????????? chromoly to mild steel [Re: all spooled up] #1596254
03/22/14 04:24 PM
03/22/14 04:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have never seen anyone weld the rose-et welds on a four link or wheelie bars when useing threaded tube ends.
Re: welding ???????????? chromoly to mild steel [Re: FastmOp] #1596255
03/22/14 04:44 PM
03/22/14 04:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All my inserts are puddle welded... front steering
links as well as all the 4 link stuff.. and on every
chassis that leaves my shop.. I was taught by a chassis
guy and he said it is required.. I think I seen it
in the NHRA rule book back a few years ago
EDIT
I know I seen it in the book.. but it was if you
were splicing in a piece in tubing(with a inner tube
inside the outer it is required) so this is basically
no difference except its not in a certed area but
it is for strength
Re: welding ???????????? chromoly to mild steel [Re: MR_P_BODY] #1596256
03/22/14 04:52 PM
03/22/14 04:52 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
Mr P you are correct it is required and it is required to be at least 1/4 hole to plug weld.
