Dana 60 ? - All the Same???
#1596139
03/21/14 12:55 PM
03/21/14 12:55 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
ad for a ford dana I want to buy it to narrow put under a dart I gave away my extra dana, to help a member on here not thinking i would need another one. Would the spool (4.10) for a dodge dana be the same I know i would have to get axles and housing ends/backing plate etc http://nashville.craigslist.org/pts/4361331857.html
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
Re: Dana 60 ? - All the Same???
[Re: draginmopars]
#1596140
03/21/14 04:26 PM
03/21/14 04:26 PM
Posts: 43,202 Bend,OR USA
Cab_Burge
Be very careful on the Ford Dana 60, 60-1,60-2, 61 and the other Dana Corp. rear end versions that Ford used If it is a Dana 60 it should have the 60 cast into the passenger side lower reinforcing webbing between the axle tube and the center section If it doesn't have it look for one that does BTW, I have seen Dana 60 with 3.0,3.125 and 3.250 diameter axle tubes also The stock Mopar passenger car tubes where 3.0 just like the 8 3/4 where
[Re: draginmopars]
#1596142
03/22/14 01:48 AM
03/22/14 01:48 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Make sure its a 60 and not a 61, with the gear ratio being a 4.10, it most likely is. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
