Re: Finding leaky Ign wire?
[Re: gdonovan]
#1596111
03/21/14 11:05 AM
03/21/14 11:05 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Mix up a slight salt solution in tap water.Then mist the wires and cap down with a spray bottle.If you can do it where its a bit dark even better.Thats all I used at work for 30 years.Found many bad wires ,caps and plugs that way.Sometime you will get a carbon track on the plug porcelian and great what you have.Rocky
Chrysler Firepower
[Re: therocks]
#1596112
03/21/14 11:42 AM
03/21/14 11:42 AM
Posts: 4,950 WI
Dcuda69
WI
I have done this for over 30 years also!! Poor man's scope Works like a charm!
[Re: gdonovan]
#1596115
03/21/14 03:37 PM
03/21/14 03:37 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
http://wynns.ca/data/msds/english/xtend/10014.pdfSpecific gravity is 0.97 which is less than water and salty water would be 1.01 or more MSDS says decomposition products may contain nitrogen or carbon so maybe dissolved ionic fertilizer in water? Gently sliding a grounded screwdriver along each wire sounds safe and simple.
[Re: 360view]
#1596116
03/21/14 04:26 PM
03/21/14 04:26 PM
therocks
Niles , Ohio
Get brave and wet them down then just grab them.It might shock you with what you find.LOL Rocky
Chrysler Firepower
[Re: 360view]
#1596117
03/21/14 04:30 PM
03/21/14 04:30 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I used Hi Volt for years before getting out, I should shop around for more 'cause the stuff was awesome for finding bad ignition wires.
Pull into a dark shop and spray, if the wires were bad like July 4th!
"I think its got a hemi"
[Re: therocks]
#1596118
03/21/14 04:54 PM
03/21/14 04:54 PM
Posts: 4,950 WI
Dcuda69
WI
lol....done that too!! Also very effective!
