Camshaft questions #1596035
03/21/14 01:10 AM
03/21/14 01:10 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
First of all, I know that asking about favorite cams is like asking who has the best grandchildren/what is the best color for a race car/best slicks ect, ect, but here goes.
My combo is +.030 440 w/ Ross dome pistons & H beam rods, stock stroke forged crank, unported Edelbrock RPM heads, Victor intake, 1050 Holley dominator, 2" Hooker super comp headers, 727 trans, Turbo Action "J" converter in a 3100 lb E body, Dana rear w/ 4.56, 11.5 x29.5 slicks. Race only with a mix of 1/4 and 1/8 mile. I am currently running a MP .590 solid lift cam.
A roller is not in my budget at this time, so I want to stick with a solid flat tappet.
Is there a more suitable cam for my combo? What will different lift do for me? What about duration?
Thanks,
Brian
Re: Camshaft questions [Re: '72CudaRacer] #1596036
03/21/14 01:15 AM
03/21/14 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure there is BUT you might be wasting money on
it with your stock heads... I would believe you would
be better off porting the heads... then at a later time
change cams...... JMO
Re: Camshaft questions [Re: MR_P_BODY] #1596037
03/21/14 01:24 AM
03/21/14 01:24 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
That 590 is a GOOD cam...open the heads up!
Re: Camshaft questions [Re: loaderpro] #1596038
03/21/14 02:18 AM
03/21/14 02:18 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
But would like to know what your vert is stalling at now.
Re: Camshaft questions [Re: Sport440] #1596039
03/21/14 11:50 AM
03/21/14 11:50 AM
gregsdart Offline
gregsdart  Offline
I would be in favor of porting the heads, and putting some beehive springs on it and the highest rocker ratio the whole deal will tolerate. I used an ERSON 1.75 ratio rocker many years ago on a 590 cam with ported 906 heads, and it worked well. If you don't have this cam advanced, you can work with that also. My friend Joe is making great power running that cam in a 446 with it in a 100!
Re: Camshaft questions [Re: gregsdart] #1596040
03/21/14 02:55 PM
03/21/14 02:55 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
His name escapes me but the guy on here who dyno'd the purple shafts against other cams and the similar size hughes cam made over 20 hp more than the .590.
My car is similar setup and weight to yours but my heads are ported by MCH and i reckon as it is, it would do a 10.0? with the 950 hp holley.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Camshaft questions [Re: deaks] #1596041
03/21/14 05:20 PM
03/21/14 05:20 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Mick
I believe that was Keith Dunnik and I think it was tested on a SB
Re: Camshaft questions [Re: '72CudaRacer] #1596042
03/21/14 05:33 PM
03/21/14 05:33 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Like others said, port the heads and throw on some higher ratio rockers to work better with the heads.
A cam change (staying flat tappet) might get you 1, maybe 2, tenths. A good port job could possibly find you twice that much.
Re: Camshaft questions [Re: PorkyPig] #1596043
03/22/14 12:08 AM
03/22/14 12:08 AM
Mooresburg, Tn
Mooresburg, Tn
Well, there is a good reason that I ask the questions. I changed oil and filter this week and when I cut the filter open it glittered at me. I also found several (3 or 4) small slivers of metal in it. A magnet picked up most of it. I then pulled the intake to have a look at the cam and lifters and found the #1 Ex lobe starting to go bad. Also a couple of other lobes are starting to show some distress. I have no choice now but to change the cam, and wasn't sure if I had the best choice of cam for me or not. (this cam has well over 1000 passes and has been in three different engines)
I have a OLD Cam Dynamics solid lift cam that I used in the mid 1990's that I am going to put in for now. It's a .585 lift, 310 duration, 106*, not much different than the .590 purple cam. What will 2* less duration and .005" less lift do?Also, the duration at .050" on the .590 is 265*, the Cam Dynamics is 275*. What will that change?
I know this is a lot of questions, but I'm sure to get schooled here
Thanks,
Brian
Re: Camshaft questions [Re: '72CudaRacer] #1596044
03/22/14 03:32 AM
03/22/14 03:32 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well, there is a good reason that I ask What will 2* less duration and .005" less lift do?Also, the duration at .050" on the .590 is 265*, the Cam Dynamics is 275*. What will that change?
Thanks,
Brian
The MP 590 is about 271* @ .050 duration, and it is a bad ass cam. Your specs are waay off. You havent measured one yourself, as i can tell
Re: Camshaft questions [Re: Sport440] #1596045
03/22/14 10:00 AM
03/22/14 10:00 AM
Mooresburg, Tn
Mooresburg, Tn
You are correct Mike. I used the cam card for both cams. How do I check duration of a cam? And what does changing the duration of a cam do for performance?(torque,hp,rpm range, idle smoothness... )
Thanks,
Brian
Re: Camshaft questions [Re: '72CudaRacer] #1596046
03/22/14 09:47 PM
03/22/14 09:47 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Brian that old Cam Dynamics 275 @ .050 is almost a exact replica of the MP 590 It does have 3* more duration @ .050. It will run just the same as the 590, maybe just a touch faster because of the extra duration.
A member here once swapped out the mp 590 for a Comp cam 274/282 @.050 .590/.609 on a 108 LSA and didnt see any realistic gains, even though the cam was bigger and had more lift. The LSA was more spread by 2* but overall same Et.
I agree with you on using that old Cam Dynamics cam. To measure a cams duration you need to measure it with a degree wheel.
Re: Camshaft questions [Re: Sport440] #1596047
03/22/14 11:25 PM
03/22/14 11:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If you want the same ETs you were running just stick the .585 in it.
If you want to go faster then stick the comp .650 in it.
Re: Camshaft questions [Re: FastmOp] #1596048
03/22/14 11:35 PM
03/22/14 11:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I almost was going to suggest the exact same thing/cam.
Its big though, 290/290 @ .050 .650/.650 on a 108 LSA Better have enough vert.
Re: Camshaft questions [Re: Sport440] #1596049
03/23/14 12:13 AM
03/23/14 12:13 AM
NC
440Jim Offline
440Jim  Offline
NC
Although using the Cam Dynamics cam he has is a reasonable choice if he was happy with the way the MP 0.590" ran. Here is a newer alternative to the Comp 290, 0.650".
Comp Cams MM305S-10
This is what I measured:
305º/320º@.020", 279º/287º@.050", 197º/200º@.200", 143º/143º@.300", 112º/107º@.350", 0.433"/0.420" lobe,
110 LSA (with 1.5 = 0.650/0.630)
What CR does the motor have?
Re: Camshaft questions [Re: 440Jim] #1596050
03/23/14 12:25 PM
03/23/14 12:25 PM
Mooresburg, Tn
Mooresburg, Tn
Comp Cams MM305S-10
The CR on my engine is 12.5:1. My converter is a Turbo Action "J" converter, should be plenty .
I just put a Comp Cams .650/.650 (the old McCandless grind, I think) in a friends 541 ci, Indy iron headed, Mega block engine. It just went a 5.96/115 (1/8)yesterday. I looked at that cam, but was thinking it was probably too much, given my unported RPM's heads. No since in subjecting the engine (valve train) to all that added strain, for no gain.
I'll take all the "schooling" that you guys will give.
Thanks,
Brian
Re: Camshaft questions [Re: '72CudaRacer] #1596051
03/23/14 11:08 PM
03/23/14 11:08 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
call Hughes and talk with them .
Re: Camshaft questions [Re: 493_DART] #1596052
03/23/14 11:32 PM
03/23/14 11:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'm considering the .650 for my car with 915's as my current cam is starting to go away like yours.
Bet your car would scoot with CNC'd RPM's and that Comp .650
Re: Camshaft questions [Re: 493_DART] #1596053
03/24/14 10:32 AM
03/24/14 10:32 AM
gregsdart Offline
gregsdart  Offline
