Re: Disc brake swap?
[Re: 1fastrunner]
#159560
12/01/08 02:15 PM
12/01/08 02:15 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I mounted mine in the "stock" location in front-of the spindle on my '68 A-body, and in back of the spindle on my '70 e-body (see pic) The brake lines and calipers you need to use differ depending if you put them in the front or rear of the spindles. This link has some good info. You can also look up "Doctor Diff" on this site if you have further questions. He is a great resource and a good man. http://www.moparaction.com/tech/archive/disc-main.html
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 1fastrunner]
#159564
12/02/08 04:53 PM
12/02/08 04:53 PM
RapidRobert
NO. If on this car the brake hard line/neoprene hose bracket is BEHIND the UCA AND you can mount the calipers in the front & they WONT interfere with the sway bar then that is what you want to do. Just use the particular spindle on the drivers side that will position the caliper mounting holes on the front side which means the other spindle when mounted on the passenger side will automatically position the caliper mounting holes to the front also.
[Re: RapidRobert]
#159565
12/02/08 05:04 PM
12/02/08 05:04 PM
Posts: 15,487 Florida
scratchnfotraction
the spindle from an A-body with out the bottom ball joint bolted to it will go on ether side the lower bj is side specific as well as the caliper bracket mounted front or back makes no diff in stopping you just want to go with the way the brake line is set up for front or rear mount of the caliper ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: AndyF]
#159566
12/02/08 07:03 PM
12/02/08 07:03 PM
jbc426
West Coast, USA
Right, it doesn't matter in terms of interference but the hose routing is better if the calipers are to the front of the spindle. When the calipers are to the rear of the spindle you have a short hose that has to routed just right or else it will kink. In front of the spindle you can use an off the shelf hose without any problems.
For the record, I used the 70-74 E-body calipers and hoses for the front mounted position on my '68 A-body conversion and 78 C-body calipers with GM/Firebird hoses for the rear mount conversion on my '70 E-body. The later uses a banjo style conection, and fit's beautifully. I'd have to look up which year the hoses are, or just ask Dr. Diff. That's where I got my parts.
