Disc brake swap? #159559
12/01/08 01:20 PM
12/01/08 01:20 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I just got a set of disc brake spindle assembly off a late model A-body. It already has the large caliper adapters with 11" rotors. How can I tell which side is which and do they need to be reversed for my application on my '71 Road Runner. I want to disassemble them and clean them up, but I want to be sure I can tell which one will go on which side. I remember hearing something about reversing them in some applications because of the hose routing.
Re: Disc brake swap? [Re: 1fastrunner] #159560
12/01/08 02:15 PM
12/01/08 02:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I mounted mine in the "stock" location in front-of the spindle on my '68 A-body, and in back of the spindle on my '70 e-body (see pic) The brake lines and calipers you need to use differ depending if you put them in the front or rear of the spindles.
This link has some good info. You can also look up "Doctor Diff" on this site if you have further questions. He is a great resource and a good man.
http://www.moparaction.com/tech/archive/disc-main.html
Re: Disc brake swap? [Re: jbc426] #159561
12/02/08 12:09 PM
12/02/08 12:09 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I think with the sway bar on the 71 it doesn't matter whether you mount the front or rear caliper. Just make sure the bleeder screw is UP.
Re: Disc brake swap? [Re: Jim_Lusk] #159562
12/02/08 03:55 PM
12/02/08 03:55 PM
AndyF Offline
AndyF  Offline
Right, it doesn't matter in terms of interference but the hose routing is better if the calipers are to the front of the spindle. When the calipers are to the rear of the spindle you have a short hose that has to routed just right or else it will kink. In front of the spindle you can use an off the shelf hose without any problems.
Re: Disc brake swap? [Re: AndyF] #159563
12/02/08 04:09 PM
12/02/08 04:09 PM
So, if the calipers are in the front, I can use whichever spindle I need on whatever side to have the calipers on the front?
Re: Disc brake swap? [Re: 1fastrunner] #159564
12/02/08 04:53 PM
12/02/08 04:53 PM
NO. If on this car the brake hard line/neoprene hose bracket is BEHIND the UCA AND you can mount the calipers in the front & they WONT interfere with the sway bar then that is what you want to do. Just use the particular spindle on the drivers side that will position the caliper mounting holes on the front side which means the other spindle when mounted on the passenger side will automatically position the caliper mounting holes to the front also.
Re: Disc brake swap? [Re: RapidRobert] #159565
12/02/08 05:04 PM
12/02/08 05:04 PM
scratchnfotraction Offline
the spindle from an A-body with out the bottom ball joint bolted to it
will go on ether side
the lower bj is side specific as well as the caliper bracket
mounted front or back makes no diff in stopping
you just want to go with the way the brake line is set up for front or rear mount of the caliper
Re: Disc brake swap? [Re: AndyF] #159566
12/02/08 07:03 PM
12/02/08 07:03 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
For the record, I used the 70-74 E-body calipers and hoses for the front mounted position on my '68 A-body conversion and 78 C-body calipers with GM/Firebird hoses for the rear mount conversion on my '70 E-body. The later uses a banjo style conection, and fit's beautifully. I'd have to look up which year the hoses are, or just ask Dr. Diff. That's where I got my parts.
