Re: 89 D150 A999 auto have electronic LU converter?
[Re: 383man]
#1595617
03/20/14 08:24 AM
03/20/14 08:24 AM
Posts: 1,176 Crockett ,TX
98RAM1500
Crockett ,TX
Its a 3spd auto, so basically most of the 80's 904's & 999's where electronically controlled converters? Is there anything I can do to get rid of the electronic crap? Because im not wiring up a switch to turn it on & off. What years 904's do I need to look for that's not Electronic Lockup?
[Re: scratchnfotraction]
#1595620
03/20/14 06:53 PM
03/20/14 06:53 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
From what I remember it should use a lock-up relay that is controlled by the PCM. That way the PCM know when its in 3rd gear and know the eng temp , TPS volts , vehicle speed and MAP volts to determine when to apply the lock-up. You can leave it unhooked and it just wont have the lock-up. On that year it will set a code but should not turn on the Ck Eng lite. Or you can use the lock-up which is a good idea for cruising as I believe there are some aftermarket kits around that will apply the lock-up by speed along with eng vac and temp. I dont know if the aftermarket kit will monitor TPS. Maybe someone will chime in who knows what company makes the kits, Ron
[Re: 98RAM1500]
#1595621
03/20/14 07:30 PM
03/20/14 07:30 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
A-999 they are hydraulic controlled.
we used to have to change the spring in the valve body to delay lock up
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: 383man]
#1595624
03/21/14 05:39 PM
03/21/14 05:39 PM
Posts: 25,945 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No 3-speed Torqueflite has electrical lockup, only the OD trans has it.
The electrical connection on some late 904/999 is to unlock the converter only.
[Re: John_Kunkel]
#1595625
03/21/14 07:51 PM
03/21/14 07:51 PM
383man
Balt. Md
John what do you mean unlock only ? Heck my 88 pick-up had the 3 speed with the lock-up but they do call the relay the Part throttle unlock relay. Course how can you unlock it without it having a lock-up converter ?
[Re: 383man]
#1595626
03/21/14 08:34 PM
03/21/14 08:34 PM
John_Kunkel
Rio Linda, CA
The converter locks up hydraulically with no electrical assist, it can unlock either hydraulically or on electrical command from the controller.
Of course, this is predicated on it being a lockup trans.
[Re: John_Kunkel]
#1595627
03/22/14 12:40 AM
03/22/14 12:40 AM
383man
Balt. Md
I agree but I always considered it electrical because from what I remember the solenoid has to be closed to close the bleed off vent or it wont build the pressure to move the valve. Not trying to make a big deal out of it but I just called it an electrical lock-up because of that. Thanks for the reply. Ron
[Re: 383man]
#1595628
03/22/14 12:52 AM
03/22/14 12:52 AM
98RAM1500
Crockett ,TX
So if I leave it unplugged what will happen?? will it lockup but then not unlock?? My friend (known him for 20 years) that owns the transmission shop told me that "If I left it unhooked then I will have no lockup at all and that it would shift like a regular 3spd" He's never steered me wrong before and has built trans for me in the past , plus the 40 years experience building transmissions that he has.
[Re: 98RAM1500]
#1595629
03/22/14 02:45 AM
03/22/14 02:45 AM
383man
Balt. Md
If you leave it unpluged it should not work and it will work as a standard converter. With it unhooked it wont build enough pressure to move the valve and it wont work the lock-up. Ron
[Re: 383man]
#1595630
03/22/14 04:10 PM
03/22/14 04:10 PM
John_Kunkel
Rio Linda, CA
Simple enough to test for yourself, disconnect the wire and let it shift through the gears at very light throttle....watch the tach for an rpm drop after the 2-3 shift is complete or wait for the feel of the lockup.
