69 B body woodgrain steering wheel #1595559
03/19/14 11:19 PM
03/19/14 11:19 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
Does anyone have the measurements of this steering wheel? I'm installing an ididit tilt steering column in my 69 bee and my original woodgrain wheel won't mount on it. I have to go with aftermarket mounting kit and an aftermarket steering wheel and would like to get as close to original as possible in size of the wheel. Thanks
2020 RAM Longhorn 4x4
2022 Jeep Grand Cherokee Overland
Re: 69 B body woodgrain steering wheel [Re: 7812845] #1595560
03/20/14 09:31 AM
03/20/14 09:31 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
If I read this right, you have an original woodgrain steering wheel and you are asking for the measurements of a woodgrain steering wheel? Am I missing something here?
Re: 69 B body woodgrain steering wheel [Re: Pntastar69] #1595561
03/20/14 10:26 AM
03/20/14 10:26 AM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
It's in storage about 30 miles away.
Re: 69 B body woodgrain steering wheel [Re: 7812845] #1595562
03/20/14 10:47 AM
03/20/14 10:47 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
That makes sense.
Give Dave Tays a call
http://www.rimblowsteeringwheels.com/
Re: 69 B body woodgrain steering wheel [Re: 7812845] #1595563
03/21/14 01:38 AM
03/21/14 01:38 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Measured the one in my '69 Charger. It is 15-7/8" outside diameter.
Re: 69 B body woodgrain steering wheel [Re: moparfan53] #1595564
03/21/14 09:43 AM
03/21/14 09:43 AM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
Is the offset about 5 1/2 inches?
Re: 69 B body woodgrain steering wheel [Re: 7812845] #1595565
03/22/14 08:52 PM
03/22/14 08:52 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Offset is about 5" to 5-1/4", depending if you measure from the top or bottom of the spokes where they join together.
Re: 69 B body woodgrain steering wheel [Re: moparfan53] #1595566
03/22/14 10:24 PM
03/22/14 10:24 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
Got it. Thanks to all.
