Re: Rocker arms, shafts, pushrods - Recommendations for 440
[Re: frank]
#159554
12/01/08 01:21 PM
12/01/08 01:21 PM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Thanks... I'm not looking to go to rollers, just something like the Crane adjustable I thought might be a nice upgrade. Anyone else? Is just a package like this from Mancini Rocker and Shaft Kit with some new pushrods a good enough choice?
[Re: Ludington1]
#159556
12/01/08 01:52 PM
12/01/08 01:52 PM
BradH
My ... Buy new OEM-type stamped rockers and correct-length pushrods (or some adjustable-length pushrods) and be done with it. They're simple, effective and light weight. You don't need adjustable rockers (as long as you get the correct pushrod). Since the Voodoo cam is a fast-lift hydraulic profile, increasing the ratio from 1.5 to 1.6 is likely to result in the valve train experiencing harmonics issues at an earlier RPM than it does w/ the lower ratio. As far as shafts... if your current shafts show signs of wear, replace them w/ the common standard-duty hard-chromed shafts like Mancini and 440 Source offer.
[Re: Ludington1]
#159557
12/01/08 01:54 PM
12/01/08 01:54 PM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
I have the Crane setup from Summit. I have several thousand miles on my motor over the past 8 years and they looked fine last time I had the covers off. I don't recall what pushrods I used. For some reason, I don't recall using the stock pushrods and having to purchase a set.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
