383 shaker info #1595290
03/19/14 10:13 AM
03/19/14 10:13 AM
italy
antonellomopar Offline OP
italy
Hello
I have a shaker baseplate that I would like to use to add a shaker hood to my 71 Cuda 383 4 speed. Baseplate is marked with part number 3512764 made in Canada. It's a single four barrel base. Anybody knows application for this base?
Also, would need to purchase the hex mounting stud reproduced by a gentleman in NY, that connects the engine to the shaker base. Can someone let me have contact info for him?
Thank you
Re: 383 shaker info [Re: antonellomopar] #1595291
03/19/14 10:47 AM
03/19/14 10:47 AM
MD
floyd Offline
floyd  Offline
MD
That's a 71 340 base. Does it have the two 90 degree tabs spot welded on the underside front? That base is about 1/2 inch shorter than the 383 base so the scoop will fit a little lower. I have the contact info for the guy that made the 383 mounting stud. I'll dig it up this evening.
Here's some info in a previous post that may help:
https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: 383 shaker info [Re: floyd] #1595292
03/19/14 11:45 AM
03/19/14 11:45 AM
italy
italy
Thank you Floyd. There are no feet welded on the underside. Here is part number stamped on baseplate
So it seems I will have to add a couple of centimeters to the lower part of the base. Thank you for the info
Re: 383 shaker info [Re: antonellomopar] #1595293
03/19/14 09:12 PM
03/19/14 09:12 PM
MD
floyd Offline
floyd  Offline
MD
PM sent with contact info.
Cool parts - base plate and adapter ring - are both NOS? Maybe you can trade someone for the correct 383 base plate?
Re: 383 shaker info [Re: floyd] #1595294
03/20/14 05:17 AM
03/20/14 05:17 AM
italy
italy
yes, both NOS. Found a complete shaker set up for a 71 Cuda in France a couple of years ago...hood and everything, and would love to install on my 22.000 miles 71 Cuda 383 4 speed....
Thank you for your help Antonello
