Re: CHECK ENGINE LIGHT 2009 5.7 1500
[Re: rickb67]
#1595274
03/19/14 12:08 PM
03/19/14 12:08 PM
Guitar Jones
Broken valve spring, common problem.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: rickb67]
#1595276
03/20/14 02:44 PM
03/20/14 02:44 PM
Guitar Jones
#7 plugs are sutted up. Has to be broken spring.
Yeah and of course it's on the hardest cylinder to access. It can be done in the truck though. I pull the inner fender to increase access.
