Transgo Shift kit question (SK TF SC) #1594946
03/18/14 08:39 PM
03/18/14 08:39 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Hey guys,, if any of you have installed the transgo auto trans
shift kits SKTFSC or TF1 or TF2. a couple of quick questions...
1) Did you have to make any fuel/ignition timing changes after
installing the shift kit?
I'm noticing a hesitation from a fully stopped position with light
or medium throttle pressure it bogs down/ hesitates.
I never had that before..
Some times when I snap the accelerator I get a backfire through the
carb...
Again never had this problem before the shift kit...
2) Did any of you notice a sort of double hit when shifting from 1st
to 2nd? it's kind of strange actually, the car feels like its
shifting from 1-2 twice... the first one is kind of weak the next on
is firm....and no it's separate from the 2-3 shift.
I'm quite sure I followed every instruction provided with the kit....
but obviously I'm DIY so I'm the only one to blame
Anybody have any experience with this?
Any help would be appreciated!
The only thing that has changed is the shift kit...
but I also added a 2qt deep aluminum oil pan and 2 more qts of auto trans fluid if that matters....
Thanks for the ad....
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594947
03/18/14 09:03 PM
03/18/14 09:03 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've used a tf1 and tf2 and never experienced any issues needing a tuning change. the tf2 will need a throttle pressure change, or at least the one i did needed a change.
Re: Transgo Shift kit question (SK TF SC) [Re: lewtot184] #1594948
03/19/14 09:30 AM
03/19/14 09:30 AM
O
OLD318 Offline OP
OLD318  Offline OP
O
The instructions did include a section on throttle pressure change.
FWIW, I made that per the instructions and verified it on the car.
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594949
03/19/14 12:59 PM
03/19/14 12:59 PM
regarding (1) there's something unrelated (to the trans) going on. something got bumped/changed or just a coincidence that it happened right when you added the shift kit
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594950
03/19/14 02:34 PM
03/19/14 02:34 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
727 or 904?
Re: Transgo Shift kit question (SK TF SC) [Re: John_Kunkel] #1594951
03/19/14 06:18 PM
03/19/14 06:18 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Its the original 1970 904
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594952
03/19/14 08:31 PM
03/19/14 08:31 PM
Rio Linda, CA
Rio Linda, CA
Is the "double hit" on the 1-2 shift in Drive or only when shifting 1-2 manually?
Re: Transgo Shift kit question (SK TF SC) [Re: John_Kunkel] #1594953
03/20/14 09:09 AM
03/20/14 09:09 AM
O
OLD318 Offline OP
OLD318  Offline OP
O
Thank you for replying, it only occurs in drive.
If I start in 1st...accelerate and manually shift to 2nd it works
great... manual 2nd to drive also shifts great....
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594954
03/20/14 07:03 PM
03/20/14 07:03 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Another couple of questions (if anyone knows)
The instructions say to use a file a notch the manual valve opening.
What exactly does this do?
And what does the new manual valve do vs. the old one?
if anyone knows please chime in thanks!
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594955
03/21/14 09:35 AM
03/21/14 09:35 AM
O
OLD318 Offline OP
OLD318  Offline OP
O
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594956
03/21/14 11:57 AM
03/21/14 11:57 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
The new valve is converter fill in park .file the notch more should have tool for depth transaction kit had it
Re: Transgo Shift kit question (SK TF SC) [Re: d-150] #1594957
03/21/14 04:29 PM
03/21/14 04:29 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Thanks for the input, ythere was no depth specified in the
instructions only a picture of what it should look like which I
duplicated as best I could tell...
What is the purpose of the notch?
Re: Transgo Shift kit question (SK TF SC) [Re: OLD318] #1594958
03/21/14 05:14 PM
03/21/14 05:14 PM
Rio Linda, CA
Rio Linda, CA
The notch is a fairly recent addition to the instructions, the previous instructions for the modified manual valve didn't call for the notch and those seem to work OK.
I haven't a clue what the notch does.
