Can someone explain a "dial back timing light"? #1594892
03/18/14 06:34 PM
03/18/14 06:34 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
Don't know much about them
Can someone explain their use?
Do they measure initial and total timing?
I was going to pick up one I saw at a local pawn shop, $15.oo, but of course no original packaging or instructions.
Trying to get my timing dialed in, wanting to know total timing, etc.
Re: Can someone explain a "dial back timing light"? [Re: MileHighDart] #1594893
03/18/14 06:44 PM
03/18/14 06:44 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
If you set the dial to 0 it operates like a normal like. Set it to 30 (or whatever number), and now whenever you 0 the timing on the harmonic balancer you will have 30 degrees of timing at that RPM.
Make sense?
Re: Can someone explain a "dial back timing light"? [Re: GTX MATT] #1594894
03/18/14 06:59 PM
03/18/14 06:59 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Especially usefull on balancers that do not have timing marks where you need them or wehre the line gets blocked by the alternator or some other engine component.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Can someone explain a "dial back timing light"? [Re: MileHighDart] #1594895
03/18/14 07:07 PM
03/18/14 07:07 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They usually have a knob on them that you dial your desired advance to. Say you want 18 BTDC initial so you dial 18 and point it at the mark and if it is at 18 it will show the pointer at ZERO or TDC. If not not you adjust the dist until it is. Same with total. Set the dial to say 36 BTDC, rev it up to whatever rpm max timing is, say 3000 RPM and if the pointer is on zero you're golden and if it's off adjust accordingly.
It takes all the guess work out trying to figure out which mark is which.
Just so you know if your initial is where you want it but the total isn't, changing one changes the other.
Confused yet?
Kevin
Re: Can someone explain a "dial back timing light"? [Re: Twostick] #1594896
03/18/14 07:15 PM
03/18/14 07:15 PM
RoadRunner Offline
RoadRunner  Offline
I'm not sure if this is still true, but I do recall being warned that some dial backs do not like to work right with MSD or other multi spare ignitions. I am not sure if it was model or manufacturer of timing light that was the issue, age of device, or general design. I have used mine and compared the settings with my non dial back and it seems to work fine with my MSD 6AL.
2023 Ford Mach 1
Re: Can someone explain a "dial back timing light"? [Re: Twostick] #1594897
03/18/14 07:20 PM
03/18/14 07:20 PM
Lyons, CO
Lyons, CO
So then to find out what my total timing is, I could rev the engine up to 2500 or so rpm, turn the dial on the light till the timing mark on the balancer is at 0, and then the number showing on the dial is my total?
Correct ?
Re: Can someone explain a "dial back timing light"? [Re: MileHighDart] #1594898
03/18/14 07:27 PM
03/18/14 07:27 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
So then to find out what my total timing is, I could rev the engine up until the timing stopped advancing, turn the dial on the light till the timing mark on the balancer is at 0, and then the number showing on the dial is my total?
Correct ?
Re: Can someone explain a "dial back timing light"? [Re: MileHighDart] #1594899
03/18/14 07:30 PM
03/18/14 07:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Correct ?
Yes correct.
Re: Can someone explain a "dial back timing light"? [Re: mopowers] #1594900
03/18/14 07:38 PM
03/18/14 07:38 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Correct ?
This is more technically correct even if you KNOW what total mechanical advance is built into your distributor and at what RPM it maxes out.
Kevin
Re: Can someone explain a "dial back timing light"? [Re: Challenger 1] #1594901
03/18/14 07:42 PM
03/18/14 07:42 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
My Snap-on sometimes gives me fits with the MSD and good wires. I don't know about the other name brands. A buddy of mine bought a cheap one at a swap meet and it wouldn't even register the spark with anything more than a cheap set of parts store wires.
...FAFO...
Re: Can someone explain a "dial back timing light"? [Re: MileHighDart] #1594902
03/18/14 08:21 PM
03/18/14 08:21 PM
johnmilner Offline
johnmilner  Offline
i use to turn the dial until the timing marks were at zero, then just read the dial for your timing.
Re: Can someone explain a "dial back timing light"? [Re: MileHighDart] #1594903
03/19/14 01:54 AM
03/19/14 01:54 AM
A working/functioning dialback for $15, man jump on that. Prior posts have explained how to use it. You dont need the box or the instructions. As said they dont play well with MSD's & in my experience they can be off up to a degree & I ain't sure if that is because they operate on a specific time delay & I ain't sure what diameter of balancer they are calibrated for & if the different makes' of balancer diameters are enough larger or smaller in dia to skew it since the marks will go farther in the same length of time on a larger dia dampener or if there is another issue but 1 deg ain't terrible. I prefer to find exact TDC with the 10 dollar tool in the plug hole then measure/mark (4) paint slits on the dampener: 10-15-20 and my total (35 or 38) assuming the OE TDC slit is accurate & if it ain't then I make a new long one for it all the way across for (5) total. I cut a strip of newspaper & use it as a ruler cuz it is flexible & easily goes around the dampener & .0632683" is 1 degree around the circumference & use my calipers to mark it, ie 2&7/32" is 35 & 1/2 deg. Aside from all that distraction I LOVE my dialback, it's a fun toy
Re: Can someone explain a "dial back timing light"? [Re: RapidRobert] #1594904
03/19/14 02:23 PM
03/19/14 02:23 PM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
What make and model dialback do you have?
Re: Can someone explain a "dial back timing light"? [Re: markrr] #1594905
03/19/14 10:01 PM
03/19/14 10:01 PM
It's a Sears chrome dialback unit from the early 80's & I recently got careless & let the plug in cord burn on the ex manifold. Sears cannot find me a replacement cord without the timing light model number but there is NO number on it (I looked 3 times). I even opened it up & no number on the inside just some casting numbers on the inside of several of the cheap chrome large housing pieces. It says "Craftsman professional timing analyzer" on the side. EDIT This one
Re: Can someone explain a "dial back timing light"? [Re: RapidRobert] #1594906
03/19/14 11:19 PM
03/19/14 11:19 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I think they best thing about one is if you use with a timing tape you can total time at 0 on the light and be at say 36* on the tape. Then set the light to 36* and you can double check it with the crank being on TDC. Just make sure your not at 36* on the tape and then at 36* on the light. Chit will melt real fast that way...
...FAFO...
Re: Can someone explain a "dial back timing light"? [Re: RapidRobert] #1594907
03/20/14 12:38 AM
03/20/14 12:38 AM
tucson az
frank Offline
frank  Offline
tucson az
Robert that looks exactly like my timing light. I purchased back in 80's also. Model # 161.219400.
According to the owners manual (yes I still have it) pick up and cable assembly P/N 38-739
Hope this helps
Frank
Re: Can someone explain a "dial back timing light"? [Re: frank] #1594908
03/20/14 12:48 AM
03/20/14 12:48 AM
Yes Frank it definitely does as I want to keep using it if the cord ain't too expensive from Sears. Thank you much. I'll call sears with your number. EDIT Went online & it is NS1, maybe another type will fit since it is the plug wire clamp that got burnt, the "sensor" that picks up the plug wire flashes & I can easily splice the wires if that'll take care of it if I can find one
Re: Can someone explain a "dial back timing light"? [Re: RapidRobert] #1594909
03/20/14 02:31 AM
03/20/14 02:31 AM
Lyons, CO
Lyons, CO
That Craftsman light looks exactly like the one I saw for sale at the pawn shop for $15 bucks.
I'm headed back over there tomorrow to see if they still have it.
Re: Can someone explain a "dial back timing light"? [Re: MileHighDart] #1594910
03/20/14 03:13 AM
03/20/14 03:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Bought this from the Matco tool man about 5 years ago. It works great and it dead nuts accurate. And has no problems on MSD cars. Ron
Re: Can someone explain a "dial back timing light"? [Re: 383man] #1594911
03/20/14 11:39 AM
03/20/14 11:39 AM
Ron your pic reminds me, the next one I get will have a tach in it
