Which battery, red or yellow??? #1594814
03/18/14 02:22 PM
03/18/14 02:22 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
I'm an optima fan and have decided that after 12 yrs of excellent service it is time to replace my 2 batteries. I can find the red top and yellow top 34/78 units at close to the same price. Which one would be better for a dual battery installation in a race car????
Re: Which battery, red or yellow??? [Re: Blucuda413] #1594815
03/18/14 02:42 PM
03/18/14 02:42 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Matt and I use Sear Diehard Platinum batteries but I did a search for you and here's an afternoons full of reading for you.
http://www.yellowbullet.com/forum/search.php?searchid=19295154
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Which battery, red or yellow??? [Re: Blucuda413] #1594816
03/19/14 12:31 AM
03/19/14 12:31 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi ,
optima pamplet i have recomends yellow for the race car !
Re: Which battery, red or yellow??? [Re: Blucuda413] #1594817
03/19/14 12:38 AM
03/19/14 12:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume you dont run a alt... so you want a deep
cycle style... I never cared for the Opitma... JMO
Re: Which battery, red or yellow??? [Re: MR_P_BODY] #1594818
03/19/14 12:47 AM
03/19/14 12:47 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
No alt = yellow. W/ alt, use red.
I use one yellow Optima, no alt, no problem. 440, 12.5:1, small Chrysler starter, two classes each day, use a Black & Decker smart charger.
Brian
Re: Which battery, red or yellow??? [Re: '72CudaRacer] #1594819
03/19/14 02:03 AM
03/19/14 02:03 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Brian
^^^^^X2 Use them in everything I own and build even the golf cart
Most optima problems can be traced back to the owner using the wrong charger.
never use a regular charger, If for some reason it goes dead you must use a smart charger with a AGM setting.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Which battery, red or yellow??? [Re: bigtimeauto] #1594820
03/19/14 11:49 AM
03/19/14 11:49 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
If the ones that are 12 years old are still alive and kicking, I'd keep them.
I had a redtop last over 10 years of daily driving, sitting outside over the winter, etc., and now it is still going as winch power. They started making them in mexico a few years ago and quality has suffered.
But as the others have stated, yellow top for no alt.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Which battery, red or yellow??? [Re: '72CudaRacer] #1594821
03/19/14 12:26 PM
03/19/14 12:26 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Brian
Just curious, do you have to charge between rounds?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Which battery, red or yellow??? [Re: FlyFish] #1594822
03/19/14 12:50 PM
03/19/14 12:50 PM
Alexandria, LA
Alexandria, LA
Thanks for the inputs. I currently do run an alt (140amp) but I still charge between rounds. Up until a yr ago I could get the battery back to 100% between rounds but not anymore. They have never failed me but I don't want to give them the chance. I have always used a smart charger in fact I'm on my second one now. I have had as many as 7 Optimas in use at a time, 2 in racecar, 3 in motor home and 2 in the bass boat. The only one I ever had any problem with is the starting battery in the MH. I had to replace it twice after a yr of use. After the second replacement the dealer told me he wouldn't replace it again and that I must have a problem in my vehicle. I did some checking and there was a minute draw on the battery and since I could not find the source of the draw I started unhooking the battery after every use. It is now on its 3rd yr and going strong. Again, thanks for the inputs I've ordered 2 red tops to go into the race car.
Re: Which battery, red or yellow??? [Re: Blucuda413] #1594823
03/19/14 11:25 PM
03/19/14 11:25 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I use a red top for the ignition and a yellow top for everything else.
Re: Which battery, red or yellow??? [Re: FlyFish] #1594824
03/20/14 12:41 AM
03/20/14 12:41 AM
Mooresburg, Tn
Mooresburg, Tn
Brian
Yes, I charge between rounds, at least the early rounds. If I'm still in both classes late, I don't have enough time to charge much. I have actually done this several times, come back from a run, back into my pit, hook up charger, fuel the car, unhook the charger and go back to the lanes. In about the time it took to say it...
Brian
Re: Which battery, red or yellow??? [Re: '72CudaRacer] #1594825
03/20/14 12:44 AM
03/20/14 12:44 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I run 2 red tops in my 68 dart with an alternator. I leave the fans and water pump on in the pits to cool down. about every 2 runs, I do a charge on them when in the pits
Re: Which battery, red or yellow??? [Re: '72CudaRacer] #1594826
03/20/14 12:47 AM
03/20/14 12:47 AM
Mooresburg, Tn
Mooresburg, Tn
I also have a Rock Auto racing 16v battery mounted in the car, but I have never used it. Sort of my "ace in the hole". It has a 12v post in addition to a 16v post. I have it hooked to the 12v side,but with the ground off of it. It takes about 30 seconds to hook the ground cable up. If it dosn't start then, I'll move the hot cable to the 16v side. At this point it's just ballast though .
Brian
Re: Which battery, red or yellow??? [Re: '72CudaRacer] #1594827
03/20/14 09:15 PM
03/20/14 09:15 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I run 2 yellows with an alternator for over 6 years. I will buy 2 more yellows if the one's I have ever wear out.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: Which battery, red or yellow??? [Re: Blucuda413] #1594828
03/20/14 10:40 PM
03/20/14 10:40 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Yellow is a deep cycle battery ....never let me down ....
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Which battery, red or yellow??? [Re: Blucuda413] #1594829
03/21/14 01:39 AM
03/21/14 01:39 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I have used both the yellow and red batteries...
I have a couple which are > 5 years old, they still do well but I did have a red top that went bad after 2 years..
To me it seems the older ones lasted longer..
Just my $0.05...
