ok muffler time #1593977
03/16/14 06:44 PM
03/16/14 06:44 PM
ky
headhunter Offline OP
ky
whats the recommendation on mufflers? its exhaust time fo my cuda looking for a muffler that I can leave on my car for track and street the collector size is 3 1/2 inch 484 inch hemi would like it to be kinda quiet also in case I get into drag week
Re: ok muffler time [Re: headhunter] #1593978
03/16/14 06:51 PM
03/16/14 06:51 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
do you have a db reading to start?
Re: ok muffler time [Re: Clanton] #1593979
03/16/14 06:54 PM
03/16/14 06:54 PM
ky
ky
no just my ears well being lol
Re: ok muffler time [Re: Clanton] #1593980
03/16/14 07:34 PM
03/16/14 07:34 PM
Central NC
gch Offline
gch  Offline
Central NC
Run whatever you want and put some resonators in the tailpipes.I always vote for the longer case Dynomax super turbos but most go with magnaflow or dynomax ultra flow.An x pipe and resonators will help quiet the beast.
Re: ok muffler time [Re: headhunter] #1593981
03/16/14 07:41 PM
03/16/14 07:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
ok I thought you had to meet a certain db level.I posted a db chart for muffs but it was a few yrs ago.
Re: ok muffler time [Re: Clanton] #1593982
03/16/14 07:44 PM
03/16/14 07:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On drag week you just have to pass the cop test and
they are pretty easy on that... specially when you
are in a group of cars
Re: ok muffler time [Re: gch] #1593983
03/16/14 10:26 PM
03/16/14 10:26 PM
ky
ky
i wish it had enough room for an x-pipe but being a a-body with a ladder bar set up and a lot of braceing under the car not a lot of room
Re: ok muffler time [Re: MR_P_BODY] #1593984
03/16/14 10:28 PM
03/16/14 10:28 PM
ky
ky
that's good just was wanting not to make the neighbors mad when coming in from a cruise or the track at 1 or 2 in the mornings as well
Re: ok muffler time [Re: headhunter] #1593985
03/16/14 10:30 PM
03/16/14 10:30 PM
ky
ky
think a 3 inch exhaust is to small or keep it the same as the collector size
Re: ok muffler time [Re: headhunter] #1593986
03/16/14 11:21 PM
03/16/14 11:21 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
3-1/2" Hooker Aero Chambers worked well on my old Duster. They are a chambered straight through design. Not too loud, until you get on the happy pedal.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: ok muffler time [Re: DusterDave] #1593987
03/16/14 11:29 PM
03/16/14 11:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I followed Dave when I got a pipe job & a few hookers
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: ok muffler time [Re: hemi-itis] #1593988
03/17/14 01:20 AM
03/17/14 01:20 AM
My car had a three inch system from the 3.5 inch collectors straight back back to the Magnaflow 14x7x3 inch side inlet with 3 inch center outlet oval muffs mounted behind the rear end at the rear bumper You can see them if you look real closely, the pipes run from the fenderwell headers straight back under the rocker panels and then under and behind the rear wheels up to the muffs The car has ladder bars and coil over rear suspension with the stock gas tank so there was no room to run the system under the car and over the rear end housing. The muffler shop ran them like you see in the picture, the side pipes hide the ladder bar and so on The car(518 C.I. pump gas wedge) ran high nines on pump gas motor only with the exhaust system hooked up and the air cleaner on I got lots of comments on how nice the car sounded and ran at the track
Re: ok muffler time [Re: headhunter] #1593989
03/17/14 12:50 PM
03/17/14 12:50 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I have tried the 3 1/2" flowmaster race mufflers,Dynatech splitflows,Hooker Aero chambers and the 6" oval Magna flows. The Flowmasters were the most quiet out of them all but cost 1.5-2mph. I have been the fastest with the Aero chambers and they are not to bad with the noise either.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: ok muffler time [Re: headhunter] #1593990
03/17/14 12:59 PM
03/17/14 12:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Leaving out design and cost, the largest internal volume has the lowest noise and lowest power loss.
If you have to be in the car more than 1 hour you'll throw away your Flowmasters.
Boffin Emeritus
Re: ok muffler time [Re: Dap] #1593991
03/17/14 01:00 PM
03/17/14 01:00 PM
dogdays Offline
dogdays  Offline
Even a smaller diameter H-pipe will do some good, if you can squeeze it in. It's more about connecting pulses than flow, in my book.
R.
Re: ok muffler time [Re: headhunter] #1593992
03/17/14 01:29 PM
03/17/14 01:29 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have yet to talk to Hanz but HMF here in Cleveland makes custom muffs for bikes and I think they would make some for cars but for $$ savings you may want an off the shelf.
Re: ok muffler time [Re: Clanton] #1593993
03/17/14 09:45 PM
03/17/14 09:45 PM
ky
ky
has anybody tried the collector inserts? by them selves or with exhaust?
Re: ok muffler time [Re: headhunter] #1593994
03/17/14 10:12 PM
03/17/14 10:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
They`re way loud...............I run bullets on the street/track AWESOME sound................
Re: ok muffler time [Re: headhunter] #1593995
03/17/14 10:22 PM
03/17/14 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Those things are junk.. very restrictive and still
loud... I told a friend they were but he bought them
and put them in his headers.. he lost .4 in the first
pass and they got slower... by the end of the day he
pulled them out and went right back to his normal ET
Re: ok muffler time [Re: MR_P_BODY] #1593996
03/17/14 10:37 PM
03/17/14 10:37 PM
ky
ky
glad I asked I almost ordered a set
