CHALLENGER NON A/C HEATER CONTROL SWITCH #159392
11/30/08 08:52 PM
11/30/08 08:52 PM
Dennispsalm91 Offline OP
Can somebody help me hook this back up. the 2 wires that connect to the controler itself , one for the heater/defrost and the other for the temp. One of these wires is straight and the other is like a "L" which one goes were ? a pic would be great thanks
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: Dennispsalm91] #159393
12/01/08 08:02 AM
12/01/08 08:02 AM
anyone !!
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: Dennispsalm91] #159394
12/01/08 02:35 PM
12/01/08 02:35 PM
Saskatoon Sk, Canada
Mark340A66 Offline
mopar addict
Mark340A66  Offline
mopar addict
Mopar or No Car: Sold Nov/06 1970 Challenger 340 4bbl (A66 code), A833 4 speed, 3.23 SureGrip all numbers match. 03 Dodge SX 2.0 R/T 2.0L HO(CDN Neon R/T) Black w/Grey Leather, Sunroof
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: Mark340A66] #159395
12/01/08 03:21 PM
12/01/08 03:21 PM
I need to know were the wires from the control panel go. They lead to the heater box thanks
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: Dennispsalm91] #159396
12/01/08 04:11 PM
12/01/08 04:11 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Hey Dennis. Will these photos help you?
Look at the wire and the fastener area for Identification. This controls the Def. unless I am mistaken.
Joe
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: jrwoodjoe] #159397
12/01/08 04:16 PM
12/01/08 04:16 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
next connection and cable...Unless I am mistaken this is the Temp connection because it controls the amount of air going across the heater core.
Joe
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: jrwoodjoe] #159398
12/01/08 05:31 PM
12/01/08 05:31 PM
the top pic , i was having problems with the control switch on the dash . Opening and closing.Now after i took out the actual heater switch, Im not sure if the straight wire or the "L" shaped the one that goes to that top pic, goes to the top or the bottom of the actual control panel. In the second pic what does the wire that connects to the actual heater control look like ? Thanks for the pics
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: Dennispsalm91] #159399
12/01/08 06:09 PM
12/01/08 06:09 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
The closest one to being "L" shaped (mine has a curve in it) is the wire in the lower photo and it is also the longest of the two wires. Which would make since. The shorter wire as in the top photo would go to the flap in the first photo and the longer wire to the flap in the second photo.
If you look close at the photos you will also see that the mounting "bracket" for the heater control unit has a round hole and in the lower photo it has an oval hole.
Hope that helps. Joe
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: jrwoodjoe] #159400
12/01/08 06:40 PM
12/01/08 06:40 PM
Is the other end of your defrost/heater wire, the one that goes to the vent/heater/defrost switch to the left of the steering wheel. Is it straight ? mine is L shaped, i cant for the life of me figure out how it mounts to the end of the switch. It seems like it would bind up. thats the pic i would like to see, not sure if someone put the wrong thing together, maybe thats why it didnt work to begin with
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: Dennispsalm91] #159401
12/01/08 07:01 PM
12/01/08 07:01 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I may be misunderstanding you, but that first photo shows both ends in it. One end is connected to the flap still and the other end that goes to the switch is just below it. I just bent it around in the photo so you can see it. As you can see the end that goes to that switch is not L shaped..it is straight.
Joe
Re: CHALLENGER NON A/C HEATER CONTROL SWITCH [Re: jrwoodjoe] #159402
12/02/08 07:49 AM
12/02/08 07:49 AM
maybe thats why mine doesnt work right , somebody rigged it wrong thanks for the info
