Re: Late B-body Torsion Bar Question
[Re: rabid scott]
#159388
11/30/08 09:35 PM
11/30/08 09:35 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
The big block torsion bars are in fact a bigger diameter. I dont have the dimensions handy, but they will interchange with the 73-74 cars....all the way up to 79
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#159389
12/01/08 02:07 AM
12/01/08 02:07 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
since 73 all V8 and that includes SBs use same T bars, as far can tell by my Mopar catalog ( 1974 ) and as far I know is .960" bars. then just police cars got bigger than that ( 1" I think ).
the diff on Front suspension between SB and BB cars is on sway bar really, being thicker on BBs
yes, 73/79 B bodies are the same setup
Once again, that is what I'm able to say by the 74 Mopar parts catalog.
[Re: rabid scott]
#159391
12/01/08 01:06 PM
12/01/08 01:06 PM
Posts: 2,886 US of A
A38s!
US of A
About the t-bars. 73-79 B's had three different capacities. The Low rated bars were used in 73 only. The Charger would -most likely- be the Mid rating. If you check the Charger bar ends they're prob stamped 660 and 661 (RH, LH respectively). There is a High cap set ending in 664 665 that were found, typically, on A38, and other HD apps.
Are you certain you don't already have the 660, 661s?
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
