trunk installation #1593768
03/16/14 12:20 PM
03/16/14 12:20 PM
Cincinnati Ohio USA
Moeggenpar Offline OP
Cincinnati Ohio USA
I'm having a new trunk floor,rear valance with end caps, and quarter skins installed on my 68'Charger. I'll also need a rear crossmember and inner wheelhouses as you can see. Does the shock mount crossmember normally get replaced,and are there any other braces of pieces I'd need for this job? Thanks for any info
Re: trunk installation [Re: Moeggenpar] #1593769
03/16/14 02:07 PM
03/16/14 02:07 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Rear shock mount brace is not normally replaced unless it's rusted. Don't forget about the fuel tank brace, chances are it may be rusted enough to require replacement. Also a good time to really inspect the rear frame rails and rear spring hangers. I would also paint the inside of the frame rails with some good rust prevention paint while the floor is out.
Re: trunk installation [Re: wesgtx440] #1593770
03/16/14 02:27 PM
03/16/14 02:27 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
good advise on coating the inside of the frame rails. i cleaned mine real good and coated with a good rustoleum.
