Page 1 of 6 1 2 3 4 5 6
I may have messed up...Help!.. IT'S ALIVE!!!!! #1593657
03/16/14 11:44 AM
03/16/14 11:44 AM
KY
Telvis Offline OP
Telvis  Offline OP
KY
I started my freshly built 340 last night. Immediately upon startup I had quite a bit of valve train noise. I let it run for about five minutes before shutting it down in fear of doing serious damage. Might have already, I don't know. The lower end sounds fine. Just a lot of rocker noise. I confirmed it by removing the oil filler cap and could hear it. Oil pressure is good and I followed cam break in procedures. I think my mistake was using stock rockers, at least i'm hoping that's what it is. I have a 69 340 block with Speedpro forged pistons .30 over. I installed a Lunati Voodoo #10200702 cam and comp cams hydraulic lifters. I had scored a deal a like new set of Edelbrock Performer aluminum heads 6017 for the 340 and had them checked before install. Please tell me I haven't ruined the motor. If it's just the rockers can I use a set of 273 adjustable rockers and pushrods without swapping anything else out? I should have stayed away from the Eddie heads. I have always used stock heads but the aluminum heads were a good deal at $800 for the set.
That's King Weenie to you!
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593658
03/16/14 11:47 AM
03/16/14 11:47 AM
cincinnati ohio
mcat4321 Online content
mcat4321  Online Content
cincinnati ohio
what kind of oil did you use? if you did not use a break in oil, or use an additive.. you most likely killed the cam
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593659
03/16/14 11:47 AM
03/16/14 11:47 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
yes you can use the 273 rocker arms and pushrods. Unlikely you did any damage.
I am truckless..
Re: Think I may have messed up...Help!!!!! [Re: mcat4321] #1593660
03/16/14 11:51 AM
03/16/14 11:51 AM
KY
Telvis Offline OP
Telvis  Offline OP
KY
Rotella plus a bottle of break-in additive.
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593661
03/16/14 11:51 AM
03/16/14 11:51 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I started my freshly built 340 last night. Immediately upon startup I had quite a bit of valve train noise. I let it run for about five minutes before shutting it down in fear of doing serious damage. Might have already, I don't know. The lower end sounds fine. Just a lot of rocker noise. I confirmed it by removing the oil filler cap and could hear it. Oil pressure is good and I followed cam break in procedures. I think my mistake was using stock rockers, at least i'm hoping that's what it is. I have a 69 340 block with Speedpro forged pistons .30 over. I installed a Lunati Voodoo #60402 cam and comp cams hydraulic lifters. I had scored a deal a like new set of Edelbrock Performer aluminum heads 6017 for the 340 and had them checked before install. Please tell me I haven't ruined the motor. If it's just the rockers can I use a set of 273 adjustable rockers and pushrods without swapping anything else out? I should have stayed away from the Eddie heads. I have always used stock heads but the aluminum heads were a good deal at $800 for the set.
i'm going to let someone who is fimiliar with these heads confirm this but i think your valve train geometry may be off. i don't think you've actually hurt anything but i would check into that. check 'wiggle' at the pushrod.
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593662
03/16/14 11:58 AM
03/16/14 11:58 AM
cincinnati ohio
cincinnati ohio
the very next thing i would do, if you have a oil filter cutting tool, check the filter for metal..
if you do not have a cutting tool.. drain the oil through a paint strainer or a coffee filter. tip the filter and drain it too . look for metal. a small amount is expected. if you have lots of metal. there is no need to go any further.. the motor is hurt. if you have no metal keep searching good luck
Re: Think I may have messed up...Help!!!!! [Re: mikemee1331] #1593663
03/16/14 12:01 PM
03/16/14 12:01 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
I will pull the valve covers and check. Man, this is stressing me out. I have a ton of time and money in this motor... I'm kicking myself for using the stock rockers...
Re: Think I may have messed up...Help!!!!! [Re: mcat4321] #1593664
03/16/14 12:02 PM
03/16/14 12:02 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
Yep..That was on my to do list for this morning... I will report back with my findings shortly...
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593665
03/16/14 12:19 PM
03/16/14 12:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm sure your push rod length is wrong for your stock rockers. Edlebrock recommends adj rockers arms for this reason.
Hope you didn't hurt the cam or lifters or...?
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593666
03/16/14 12:20 PM
03/16/14 12:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Your statement is little confusing,was this the first time it was run ? If so you say 5 min,that is no where near break in time if that is what you mean.
Re: Think I may have messed up...Help!!!!! [Re: 62maxwgn] #1593667
03/16/14 12:53 PM
03/16/14 12:53 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
It was the first time it had been run. I shut it off after about 5 minutes because of the valve train noise.
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593668
03/16/14 01:03 PM
03/16/14 01:03 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
I just went and drained the oil. I filtered it through a coffee filter and ran a magnet through it. I didn't see any metal at all. I think my cam is still alive. I pulled one of the valve covers and the pushrods all had a bit of tension on them. They weren't loose at all. I did notice that three of the four sets of rockers had play from side to side on the shaft. One set (third from the front) were tight together. The other three sets had maybe a 16th of an inch side to side play between them. I checked and they are oriented correctly. The correct spacers are on the bolts. I did buy these off ebay because I didn't want to remove the set I had on the existing 318. Could it be the rockers are a "frankenstein" mismatched set? Just looking at the cam specs I don't see why the stock rockers won't work. I'm by no means an expert but I have head the stock stuff is fairly stout. Am I misinformed?
Here's the cam info:
Lift at valve .475 in. .494 ex
Rocker ratio: 1.500 in in. 1.500 ex
Duration at .050 Tappet lift: 220 in. 226 ex.
Duration: 265 in. 271 ex.
Re: Think I may have messed up...Help!!!!! [Re: 340SHORTY] #1593669
03/16/14 01:09 PM
03/16/14 01:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You cannot use stock 273 adjustable rocker pushrods with a hydraulic lifter cam.
To the OP, there is no real reason a stock rocker can't be used with your cam, it's mild. You really need to verify the pushrod length is correct though, which might be your issue.
Don't be the exception.
Re: Think I may have messed up...Help!!!!! [Re: Supercuda] #1593670
03/16/14 01:16 PM
03/16/14 01:16 PM
cincinnati ohio
cincinnati ohio
i disagree, i have done it.. i know others who have done it. and for years on end
Re: Think I may have messed up...Help!!!!! [Re: mcat4321] #1593671
03/16/14 01:21 PM
03/16/14 01:21 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
The more I read and look into it I am starting to think the pushrod length is my culprit. This is a new issue for me. This is my 4th motor build but my first with aluminum heads. Normally I stay relatively stock with a bore change, mild cam and stock heads. How do I figure out what length pushrod I need? is there a measurement procedure?
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593672
03/16/14 01:22 PM
03/16/14 01:22 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Did you pump the lifters full before starting the motor? Did you check the valve lash at any point - you should have no clearance and some preload with hydraulic lifters.
You've changed the heads, cam and lifters and head gaskets so more than likely measurements have changed and now the pushrods are too short.
I don't see an issue using stock rockers in a mild build.
Re: Think I may have messed up...Help!!!!! [Re: mcat4321] #1593673
03/16/14 01:23 PM
03/16/14 01:23 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Reference using 273 rockers with a hydraulic cam.
You just have to adjust them correctly. The T/A engine used adjsutables with hydraulic cams.
Careful, your character's showing!
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593674
03/16/14 01:23 PM
03/16/14 01:23 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
What kind of pistons did you use? Did you measure piston to valve clearances to make sure you are having contact there?
If the edelbrock heads are the magnum replacement part number you may have pushrods binding in the tunnels as the roller cam A engines have different pushrod geometry due to the taller lifter.
Did you fill the lifters before installing them? I've done it both ways and seen it recommend both ways. Rhoads and some others recommend submerging the lifters in oil and working the plunger in the bore with a pushrod until bubbles stop coming out. I've seen others recommend installing them dry for less initial pressure on the cam lobes. They take longer than you might expect to pump up from bone dry and sound like hell until they do.
good luck, let us know how it turns out.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Think I may have messed up...Help!!!!! [Re: Telvis] #1593675
03/16/14 01:25 PM
03/16/14 01:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yes. It usually involves buying an adjustable pushrod made for that purpose (buying two makes it easier). Most cam manufacturers sell them. They come in various lengths and end configurations.
Re: Think I may have messed up...Help!!!!! [Re: Stanton] #1593676
03/16/14 01:35 PM
03/16/14 01:35 PM
KY
Telvis Offline OP
Telvis  Offline OP
KY
Good deal...I will see if I can get some. I will have to research the procedure to determine proper length. Hopefully it will be a fairly simple process
Yes I did pump the lifters and pre lube them. The heads are 340 specific heads and not magnum heads. Speedpro forged pistons with valve reliefs (2). I don't think there any valve piston issue. The noise seemed to be coming directly from the rocker area. It became pronounced when I removed the oil filler cap. I suspect the pushrod length is incorrect. Thankfully I didn't find any metal in the motor.
