Page 1 of 3 1 2 3
Quick Swap 318 to 383 #1593567
03/16/14 10:28 AM
03/16/14 10:28 AM
West Palm Beach, Florida
Copper Dart Offline OP
My '67 Satellite 318 904 has very low compression in cylinder #1 with severe blow-by. Suspect stuck/broken rings from extended time not being started/run/driven. Other than that the car is almost a Survivor in untouched condition.
Because of it being disqualified as a Survivor, an engine swap is a good option. I would spend money and time to repair the 318 or spend about the same time and money to do a swap. With the end results of a swap being much more desirable, I chose swap.
Here it goes!
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593568
03/16/14 10:42 AM
03/16/14 10:42 AM
First thing was to pull the donor.
A '68 Newport 383 with a fresh 727 that my brother Henry (Model Maker) wasn't finding alot of interested buyers for became the Donor.
The engine ran excellent. Good compression and oil pressure. Disassembley goes much faster than assembly
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593569
03/16/14 10:43 AM
03/16/14 10:43 AM
its out
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593570
03/16/14 10:45 AM
03/16/14 10:45 AM
Time to take a closer look.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593571
03/16/14 10:46 AM
03/16/14 10:46 AM
pull the heads just to make sure everything is OK
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593572
03/16/14 10:49 AM
03/16/14 10:49 AM
steel shim gaskets right from the factory! it seems to have never been apart!
check this out, you can see something interesting here?
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593573
03/16/14 10:53 AM
03/16/14 10:53 AM
Clean clean and clean some more!
New gasket set, timing chain and some Dupli Color engine paint ready to go!
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593574
03/16/14 10:55 AM
03/16/14 10:55 AM
I did use a fresh set of 906 heads I had and was unable to sell.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593575
03/16/14 11:00 AM
03/16/14 11:00 AM
Now for the transplant patient
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593576
03/16/14 11:03 AM
03/16/14 11:03 AM
Drain fluids, pull the battery and off with hood.
Edit: Exhaust out and all linkages off and pull the driveshaft.Edit
Then drop the transmission and prop the engine pan on the steering link
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593577
03/16/14 11:05 AM
03/16/14 11:05 AM
Almost forgot
this is always nice to see!
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593578
03/16/14 11:07 AM
03/16/14 11:07 AM
now for the heart of the victim
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593579
03/16/14 11:08 AM
03/16/14 11:08 AM
Ready to pull
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593580
03/16/14 11:10 AM
03/16/14 11:10 AM
Thanks Henry!!!
Everything goes so much easier with good help
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593581
03/16/14 11:15 AM
03/16/14 11:15 AM
Out without a hitch.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593582
03/16/14 11:16 AM
03/16/14 11:16 AM
Dirty and empty
you can still see the little block of wood used to prop the engine when pulling the transmission
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593583
03/16/14 11:19 AM
03/16/14 11:19 AM
Cleaner and still empty
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593584
03/16/14 11:20 AM
03/16/14 11:20 AM
on to the install
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593585
03/16/14 11:21 AM
03/16/14 11:21 AM
new jersey
Black 69 Beeper Offline
new jersey
cool car. man its nice to get something that hasn't been messed with. keep the pictures coming.
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593586
03/16/14 11:22 AM
03/16/14 11:22 AM
its in
I will admit I was a bit nervous during the install but it went perfect!
Mom.
Ricky Valdes
Page 1 of 3 1 2 3
