Quick Swap 318 to 383
#1593567
03/16/14 10:28 AM
03/16/14 10:28 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
My '67 Satellite 318 904 has very low compression in cylinder #1 with severe blow-by. Suspect stuck/broken rings from extended time not being started/run/driven. Other than that the car is almost a Survivor in untouched condition. Because of it being disqualified as a Survivor, an engine swap is a good option. I would spend money and time to repair the 318 or spend about the same time and money to do a swap. With the end results of a swap being much more desirable, I chose swap. Here it goes!
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: Quick Swap 318 to 383
[Re: Copper Dart]
#1593568
03/16/14 10:42 AM
03/16/14 10:42 AM
Copper Dart
First thing was to pull the donor. A '68 Newport 383 with a fresh 727 that my brother Henry (Model Maker) wasn't finding alot of interested buyers for became the Donor. The engine ran excellent. Good compression and oil pressure. Disassembley goes much faster than assembly
[Re: Copper Dart]
#1593572
03/16/14 10:49 AM
03/16/14 10:49 AM
Copper Dart
steel shim gaskets right from the factory! it seems to have never been apart! check this out, you can see something interesting here?
[Re: Copper Dart]
#1593573
03/16/14 10:53 AM
03/16/14 10:53 AM
Copper Dart
Clean clean and clean some more! New gasket set, timing chain and some Dupli Color engine paint ready to go!
[Re: Copper Dart]
#1593574
03/16/14 10:55 AM
03/16/14 10:55 AM
Copper Dart
I did use a fresh set of 906 heads I had and was unable to sell.
[Re: Copper Dart]
#1593576
03/16/14 11:03 AM
03/16/14 11:03 AM
Copper Dart
Drain fluids, pull the battery and off with hood. Edit: Exhaust out and all linkages off and pull the driveshaft.Edit Then drop the transmission and prop the engine pan on the steering link
[Re: Copper Dart]
#1593580
03/16/14 11:10 AM
03/16/14 11:10 AM
Copper Dart
Thanks Henry!!! Everything goes so much easier with good help
[Re: Copper Dart]
#1593582
03/16/14 11:16 AM
03/16/14 11:16 AM
Copper Dart
Dirty and empty you can still see the little block of wood used to prop the engine when pulling the transmission
[Re: Copper Dart]
#1593586
03/16/14 11:22 AM
03/16/14 11:22 AM
Copper Dart
its in I will admit I was a bit nervous during the install but it went perfect!
[Re: Copper Dart]
#1593587
03/16/14 11:27 AM
03/16/14 11:27 AM
Copper Dart
Yes, it does help. More pictures for those of us that don't like reading On to the transmission, driveshaft (from a '67 Coronet 318 727) install and linkage Edit: We used the trans crossmember from the '67 Satellite 904, just turned the mount around.Edit
[Re: Copper Dart]
#1593588
03/16/14 11:31 AM
03/16/14 11:31 AM
Copper Dart
No exhaust to install, I will have that done at a shop. Back up top to finish the install.
[Re: Copper Dart]
#1593595
03/16/14 11:53 PM
03/16/14 11:53 PM
Copper Dart
Valve covers painted and installed. The Duralast cut to fit wire set #1600 (90* plug boots) and #1601 (straight boot) worked better than expected! $15.00 each set Running nice. I have to get the exhaust system done, I will try and find a shop tomorrow AM if possible.
[Re: Copper Dart]
#1593597
03/24/14 02:35 PM
03/24/14 02:35 PM
Copper Dart
loaded on the trailer on the way to get the exhaust installed
[Re: Copper Dart]
#1593599
03/24/14 02:46 PM
03/24/14 02:46 PM
Copper Dart
A WOPPING $800. later OUCH! I bet I could have ordered it from summit or jegs for half that. Can you say "Bait and switch"?. After loading everything up on a trailer and dropping it off, knowing I had to have it done today, or I wouldnt have taken it to a shop. I would have done it myself.
[Re: Copper Dart]
#1593600
03/24/14 02:51 PM
03/24/14 02:51 PM
Copper Dart
I had to change out the intake manifold and carb. That old 2 bbl was giving me too much trouble, hard to start, popping/coughing on acceleration, unstable idle etc.... Now it lights right off. I have to modify the throttle cable and kick down bracket to work properly and I still have to work on the bog issue but that will be for another time.
[Re: bobbyb]
#1593603
03/25/14 03:35 PM
03/25/14 03:35 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
just a TAD pricey. I've got a couple of shops around here, and none would have charged half that. car looks great
1981 Dodge D150 360 auto
[Re: basketcase]
#1593604
03/25/14 05:53 PM
03/25/14 05:53 PM
Posts: 5,161 CT
GTX MATT
CT
Man you could have gone TTI for that kind of dough. Cool though! I have a '67 Lite that was similar to yours when I got it. 383 is a great engine for a nice cruiser and driver. Nice car
[Re: GTX MATT]
#1593605
03/27/14 10:14 AM
03/27/14 10:14 AM
Copper Dart
I'm not very happy to say the least. He said it would run me $600 tops out the door. After loading it on the trailer and driving across town and dropping it off as agreed, I get a call, "its going to be a bit more, do you still want to get it done?" Thats why I said "Bait and Switch" just the cost of going to pick it up without having it done and wasting the day too, I figured the $200 was worth not having to deal with finding another shop or having to install TTI's system a week or two later myself. Some business are not being run like they were some years ago where your word meant something. The job was not done quite the way we agreed. It was supposed to be "serviceable" Un-bolt it to remove....NOT! some (not all) of the hangers have to be cut off Lesson learned (I hope)
[Re: RUNCHARGER]
#1593607
03/28/14 10:22 AM
03/28/14 10:22 AM
Copper Dart
Thanks Sheldon, I need to figure out a steel fuel line to replace the temporary rubber hose I have running from the top of the fuel filter to the carb inlet. Any ideas or suggestions will be appreciated. Idea is to have a short piece (3" or so)top of filter to a steel line and another short piece right at the carb inlet. I just cant imagine how I would bend one steel line from the filter and make it to the right rear of the carb and make it somewhat hidden? Ricky
[Re: Copper Dart]
#1593608
03/31/14 11:36 PM
03/31/14 11:36 PM
Posts: 50 Florida
1969proDart
How does that edelbrock run on that 383. Looking into getting a new carb, don't want to rebuild that old one I have, want something new and fresh. Which one you get?
[Re: 1969proDart]
#1593609
04/01/14 01:19 AM
04/01/14 01:19 AM
Copper Dart
GREAT DEAL for under $300. I just installed it and haven't had much time to play yet. # 1407 ,I was told to choose the larger of the two. (650 or 780 I think) Bolted it on and it fired right up with very little to adjust for a nice idle. Now the engine starts right up with very little cranking hot and cold. It's surprising how easy it starts, I'm very happy with the carb thus far. I did notice a bog from a dead stop in drive, like it's wanting more fuel. I must add that the converter sucks for performance ('68 Newport), say if idle is 700 RPM, it stalls at 750 RPM, REALLY! Not what I would consider keeping in it for too long. Someone out there knows what is needed to lessen the bog for now. Please chime in. Thanks in advance.
[Re: Copper Dart]
#1593610
04/06/14 08:31 PM
04/06/14 08:31 PM
Copper Dart
Vacuum advance diaphragm was bad. I pulled the distributor out rather than fighting to replace it under the hood. Man does it run better! I need to post a short video of it burning tire On a rolling start in a straight line, it will light the tire just rolling hard on the gas pedal and will chirp really well into second! I'm so surprised at how strong the 383 is. The rear end ratio is 2:73 if you were wondering.
[Re: basketcase]
#1593613
04/12/14 11:36 PM
04/12/14 11:36 PM
Copper Dart
I feel like a 16 year old horsing around the streets. Someone mentioned the 383 was going to make it a "fun to drive" car. Boy was he right, I'm enjoying it more than I had imagined. Aint she purdy?!
