Quick Swap 318 to 383
#1593567
03/16/14 10:28 AM
03/16/14 10:28 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
My '67 Satellite 318 904 has very low compression in cylinder #1 with severe blow-by. Suspect stuck/broken rings from extended time not being started/run/driven. Other than that the car is almost a Survivor in untouched condition. Because of it being disqualified as a Survivor, an engine swap is a good option. I would spend money and time to repair the 318 or spend about the same time and money to do a swap. With the end results of a swap being much more desirable, I chose swap. Here it goes!
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: Quick Swap 318 to 383
[Re: Copper Dart]
#1593568
03/16/14 10:42 AM
03/16/14 10:42 AM
Copper Dart
First thing was to pull the donor. A '68 Newport 383 with a fresh 727 that my brother Henry (Model Maker) wasn't finding alot of interested buyers for became the Donor. The engine ran excellent. Good compression and oil pressure. Disassembley goes much faster than assembly
[Re: Copper Dart]
#1593572
03/16/14 10:49 AM
03/16/14 10:49 AM
Copper Dart
steel shim gaskets right from the factory! it seems to have never been apart! check this out, you can see something interesting here?
[Re: Copper Dart]
#1593573
03/16/14 10:53 AM
03/16/14 10:53 AM
Copper Dart
Clean clean and clean some more! New gasket set, timing chain and some Dupli Color engine paint ready to go!
[Re: Copper Dart]
#1593574
03/16/14 10:55 AM
03/16/14 10:55 AM
Copper Dart
I did use a fresh set of 906 heads I had and was unable to sell.
[Re: Copper Dart]
#1593576
03/16/14 11:03 AM
03/16/14 11:03 AM
Copper Dart
Drain fluids, pull the battery and off with hood. Edit: Exhaust out and all linkages off and pull the driveshaft.Edit Then drop the transmission and prop the engine pan on the steering link
[Re: Copper Dart]
#1593580
03/16/14 11:10 AM
03/16/14 11:10 AM
Copper Dart
Thanks Henry!!! Everything goes so much easier with good help
[Re: Copper Dart]
#1593582
03/16/14 11:16 AM
03/16/14 11:16 AM
Copper Dart
Dirty and empty you can still see the little block of wood used to prop the engine when pulling the transmission
[Re: Copper Dart]
#1593586
03/16/14 11:22 AM
03/16/14 11:22 AM
Copper Dart
its in I will admit I was a bit nervous during the install but it went perfect!
