Help me identify this small block motor please
#159280
11/30/08 05:52 PM
11/30/08 05:52 PM
Posts: 169 Maine
itali83
Maine
Hey guys, I've got a small block out of a '68 Sport satellite and want to know what it is. Don't know if the motor is orig, to the car. I took a picture of the cast numbers found on the left side of the block. In the numbers is "318" so is it a 318ci? The motor has what looks to be a factory 4bbl intake. Also, there were weights on the torque converter which may help someone figure out what exactly I have. I'm looking to sell it so what is a rough idea of what it's worth? I've never had it running, never apart, it turns over by hand, no water in it Complete minus acessories. Thanks!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: Help me identify this small block motor please
[Re: itali83]
#159283
11/30/08 06:00 PM
11/30/08 06:00 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, its a 318. It isnt worth much. The 4bbl manifold is not original to the car, because the 318 wasnt available with a factory 4bbl until 1978. However, your 318 appears to have been painted blue originally. In 1968, the correct color would have been red. Im guessing someone swapped a newer 318 into your car at some point in time.
The weights on the converter are kind of puzzling. The only small block with a weighted converter would be a 360, or a 1973 340. Either way, the 318 was internally balanced. Does the balancer have a counterweight? How about some more pics
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#159284
11/30/08 06:16 PM
11/30/08 06:16 PM
Posts: 169 Maine
itali83
Maine
The weights are two pieces of metal at the edge, by the threaded mounts for the converter bolts. They are close together but not touching. The front dampener is rubber type with a metal ring on the outside of the rubber that has drill marks for balancing. There is NO sign of red, this has been a blue motor all it's life. Its dark now but I'll get some more pics when I can. I just want an idea of what I have so I can describe it the best I can when I put an ad. to sell it. Thanks!
[Re: itali83]
#159286
11/30/08 06:32 PM
11/30/08 06:32 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
How big are the weights? Alot of converters have tiny ones to balance the converter itself. If they are big thick weights like 1/4 " then it must have a 360 converter in it. Its definitly a mid 70's 318, nothing special.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 70dart360]
#159287
11/30/08 06:45 PM
11/30/08 06:45 PM
Posts: 169 Maine
itali83
Maine
Yea, it must be the wrong converter because they are big weights, not little ones for the converter itself. Thanks guys!
[Re: itali83]
#159288
11/30/08 07:18 PM
11/30/08 07:18 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
not to say that you have anything special but who knows what has been done to it in the past also just for info my X block has 318 cast in the side of it just like that along with the big X on the end also someone could of dropped a 340 cast crank in the block at some time
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 69L78Nova]
#159292
12/01/08 12:49 AM
12/01/08 12:49 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The 340 cast crank is the same part # they used in 318s of the era. The extra weight is needed because they used the same crank in the 2 motors but two different pistons. The 340 used heavier pistons but the same crank so they had to add weight to the converter and balancer to make up for the heavier pistons.
If it is a factory converter it is from a 360 because the 340 did not come with 904s.
