Mopar techs- PCM reprograming??
#159254
11/30/08 05:32 PM
11/30/08 05:32 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I have a car that I suspect has a bad PCM. Its an 01 Intrepid. I want to buy a junkyard PCM. I know the VIN and odo "are supposed to" match the info on the other on board computers but have conflicting reports after that.
Some people say it will run fine forever but will illuminate the CEL if info doesn't jive.
Others say it will start but eventually lock out if they don't match.
Also a dealer service dept I called said used PCM's cant be reprogrammed with that info and I have to buy a new one for $650..... But a tech I talked to thinks a used PCM can be reprogrammed with a DRB3 scan tool.....
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Mopar techs- PCM reprograming??
[Re: SALEM1912]
#159256
11/30/08 06:42 PM
11/30/08 06:42 PM
CJK440
Ansonia, CT
Dealer wants $650 for a programmed PCM. I have only 1300 in the car itself. The car does not have a SKIM key.
The car is eating cam sensors, 5 in all, 2 mopar, 2 borg warner and 1 wells. All wiring involved from the PCM connector out (to sensor connector and ground) checks out fine, even with a load on it.
PCM is outputting the right supply voltage and the signal looks OK.
[Re: Fastfrankie]
#159258
12/02/08 05:08 PM
12/02/08 05:08 PM
CJK440
Ansonia, CT
FAST- I got my eye on some of the ebay companies but this is still a hunch. If mismatching VIN's will allow the car to run fine but just illuminate the CEL, I'd much rather spend $55 for a used PCM just to test my theory rather than spend $200 and find it wasn't the PCM.
Salem- My car doesn't have SKIM or anti theft. Its a real base model. The Junkyard has a matching P/N PCM.
[Re: moparmandc]
#159260
12/02/08 07:41 PM
12/02/08 07:41 PM
CJK440
Ansonia, CT
Somehow I am thinking those ebay shops just buy up used computers, reflash the vins and kick them out the door and let the customer find out if its good or not. Warantee is only good once they get the core back. I can't really see them going in and changing electronic componants for $200.
[Re: CJK440]
#159261
12/02/08 08:28 PM
12/02/08 08:28 PM
Posts: 1,755 Washington Twp., Southern NJ
Fastfrankie
Well then bite the bullet and spend $600 for a Mopar one if you think the guy is selling junk. The guy had 100% positive feedback on Ebay and has sold a ton on there. I spoke with their tech people when I gave them my info and they were professional and helpful. My time is money. For $200 shipped to me, the car was back on the road within three days. Farting around with used ones, throwing parts at a vehicle, finding someone to program it all cost time and money too with no guarantees.
I dont care what he does to them or where he buys them from - it worked for me and still is fine 10 months later and I didn't have to spend $600 plus tax at the stealer. I avoid the stealer like the plague...especially the one closest to me!
Or buy one for $55 at the yard and possibly deal with more headaches and finding someone to flash/program it.
My buddy owns a junkyard and wouldn't even GIVE me one for free. I'd still have to take it somewhere and pay someone to program it/flash it etc and that's gonna cost me money...and hope it works when I install it. Its a gamble...
He won't even sell used PCMs...not worth the headache/hassle of people calling him back bitching about it not running right, not starting etc. He'd rather sell 2007 Caddy clips for $7,000 than sell a used PCM for chump change...
[Re: Fastfrankie]
#159262
12/02/08 09:09 PM
12/02/08 09:09 PM
Posts: 862 Southeast Pa.
SALEM1912
Southeast Pa.
CJK440 can you give me the #pn,did you ask your dealer if a reman is available? Whats the problem no start/check engine light on/cranks long then fires up? what engine2.7 3.5 ?
[Re: Fastfrankie]
#159263
12/02/08 09:11 PM
12/02/08 09:11 PM
CJK440
Ansonia, CT
Whoa, keep your pants on buddy. I'm not saying they are junk, but those ebay houses advertize "reman" computers and I doubt there is much remanufacturing going on for that price. I think they are just reprogrammed used computers and if one is bad there is another on the shelf right behind it thats probably good. The reprogramming thing with a JY computer is a PITA but so is $200 to find it wasn't my problem in the first place.
[Re: CJK440]
#159265
12/03/08 12:16 AM
12/03/08 12:16 AM
SALEM1912
Southeast Pa.
CJK are you by chance near Claremont N.H. a dealer has that #pn and would most likely sell it to you for cost 372. If you are near call him and ask if he'll sell it to you. Old stock he should want to move it.603-543-0188 Lambert Auto Sales. Reman is around 580. What size engine??? Have you replaced the crank sensor? As odd as it seems sometimes the faulty sensor is reported wrong. I would have replaced both. As for switching when it cuts off it may have cooled down enough while you where switching sensors. A hair line crack in the magnet of these sensors is all it takes to shut you down,when it cools the crack goes away it restarts.
[Re: CJK440]
#159268
12/03/08 09:12 AM
12/03/08 09:12 AM
CJK440
Ansonia, CT
Salem,
Since one of the failures threw a crank sensor code even tho it was the cam sensor, I put a parts store crank sensor in and eventually updated it with a Mopar part because everybody says the other brands are junk.
[Re: Dakota_Don]
#159271
12/10/08 11:53 AM
12/10/08 11:53 AM
CJK440
Ansonia, CT
Alternator. I was close to buying a PCM but tried this first. Glad I waited.
