I use the two threaded bolt holes at the center of the hub at the bottom of the can and a harmonic balancer puller.
When you remove the nut on the end of the shaft you will see two small threaded holes next to the shaft end. There is a 3rd hole for the horn wire that isn't tapped. They have to be long and preferably grade 8 bolts if possible. If the puller starts to walk off of the end of the shaft put a nut on the end of the shaft and only run it down about 4 or 5 turns. Not enough to keep the can from coming loose but enough to hold the end of the puller's center bolt so it won't walk.
It will be tight but it will pop loose.
