Re: Warped hood or am I missing something?
[Re: Steve Bryant]
#1592353
03/13/14 04:13 PM
03/13/14 04:13 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I'm just guessing here.....sounds like you have a hinge issue. I have seen this happen on a couple of 71-72 B bodies. A fresh set of hinges cured the issue.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: burdar]
#1592355
03/13/14 05:31 PM
03/13/14 05:31 PM
Challenger 1
Cincinnati, Ohio
If the hinges aren't worn, it's an adjustment issue. Look on Resto Rick's website for adjusting tricks. My Challenger hood did the same thing. It was an adjustment issue. You kind of have to adjust the hinges the opposite of what you'd think in order to get the back of the hood to sit down flush with the fenders.
This ^^^^^ Too many hinges have been rebuilt for this reason and they did not need to be rebuilt.
[Re: Challenger 1]
#1592361
03/13/14 09:16 PM
03/13/14 09:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
....just another E body curse, rising hood corner (always the drivers side too ) rattling doors/windows, and C pillar telegraphing, having owned E bodies since the mid 70's, this is the most annoying symptom...Resto Rick has some great tips for those uninitiated with E bodies
Mike
[Re: Steve Bryant]
#1592364
03/14/14 12:28 PM
03/14/14 12:28 PM
Posts: 1,023 pa.
dan9
pa.
I would loosen the front and bottom rear hinge bolt then raise the hood maybe a little beyond where it rests in the open position. In other words rock the hinge bringing the front up, it looks like that is your problem. As said before, it's opposite of what you would think.
