Re: Best 915 head 440ci race only intake?
[Re: RockChip]
#1592173
03/12/14 10:53 PM
03/12/14 10:53 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Best over all I would presume is the Weiand 2-4bbl Tunnel Ram. I would also presume the Edelbrock Victor for the single 4bbl.. I'm running a Wieand X-Cellerator currently BTW I have both the above intakes for testing..... someday ![](/ubbthreads/images/graemlins/rolleyes.gif)
[Re: wyoming]
#1592175
03/13/14 12:12 AM
03/13/14 12:12 AM
Posts: 684 toronto
6PAK70CUDA
toronto
back when I was running a 915 headed engine, the old TM7 worked pretty darn good, dont see them talked about much anymore.
I ran a 500 in stroker and the TM7 with a Dominator on an adaptor was quicker than the Dominator on a 4500 flange Weiand.
[Re: slippery440]
#1592181
03/13/14 12:13 PM
03/13/14 12:13 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I used to run a engine with ported 915 heads the Weiand with 2 Holley 650 double pumpers made the most power the 2nd one on power was the STR-14 intake with the same 650 Holley DP the 3rd best was the TM-7 with a 1050 dominator.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: RockChip]
#1592182
03/13/14 04:31 PM
03/13/14 04:31 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I dynoed said engine with a team G
One of, if not the worst intake for a RB...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1592183
03/13/14 04:38 PM
03/13/14 04:38 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Another thing to consider...the added plenum volume of the 4500 manifolds will make more power on the dyno, but not necessarily run better at the track. Need to know more about the combo to recommend a manifold. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 70dusterjohn]
#1592189
03/14/14 08:06 AM
03/14/14 08:06 AM
Posts: 1,629 pa
572charger
pa
our old 73 cuda race car 3500 lbs, trw 30 over 440 slightly ported 906s, 590 cam,TM-7, 850 holley out of the box,turbo action3800, 456 gear 10x28 slicks ran 10.80s, 10.90s all day long on pump gas , we had real pumpgas back in the 80s ![](/ubbthreads/images/graemlins/thumbs.gif)
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
