Re: 440 Bore size Ford pistons?
[Re: JeffL]
#1592148
03/13/14 02:04 AM
03/13/14 02:04 AM
RapidRobert
I'd start by checking the bore sizes of the commonly available BB head gaskets. Compare that to the 4.390" block bore you have. Not sure how much less you need on the gasket bore dia. That'd be a start
[Re: Cab_Burge]
#1592150
03/13/14 09:36 AM
03/13/14 09:36 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Don't forget any chamfer (sp?) at the top of the bore as well. My first build I used "standard bore size" gaskets. Never checked the overhang into the bore. My fault. Part of the fire ring went away. Not a good day. Just something to check. I cannot comment for sure, but I've heard some blocks have a larger chamfer than others codfish
[Re: JeffL]
#1592155
03/13/14 03:37 PM
03/13/14 03:37 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
They are Eddy 84cc aluminum heads. The fel-pro gaskets that were in the engine seem to block part of the cylinder. I will post some pictures later.
Sounds like a late block with a large chamfer at the top of the bore ?
[Re: JeffL]
#1592157
03/13/14 04:22 PM
03/13/14 04:22 PM
Posts: 596 Mass.
80fbody
Mass.
Check the attached post. Most of the available gaskets are listed. Other option is Cometics. Can be custom made to your specs & are typically re-usuable. Run around $200-$250 per set. https://board.moparts.org/ubbthreads/show...&PHPSESSID=The marine gasket has a pretty good rep here & looks to be the right size for you. Lots of those on engines here.
