DTC Check #159211
11/30/08 02:30 PM
11/30/08 02:30 PM
Winnipeg, MB
sreinheimer Offline OP
Winnipeg, MB
how do you check codes on a 91 daytona? My friends car will crank but not start and i want to see if it has any codes
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: DTC Check [Re: sreinheimer] #159212
11/30/08 03:22 PM
11/30/08 03:22 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I think with a 91 you can still try the old true method of cycling the key from off to on, 3 times (leaving it on the third time) and count the flashes of the check engine light.
55 is end of codes.
