88 YJ vac hoses #1592053
03/12/14 05:14 PM
03/12/14 05:14 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
this thing has like a gazillion vac hoses every where, most are rotted or caped off from prev. owner.can i just eliminate them and keep theones i need like dist.,carb and brakes?
Re: 88 YJ vac hoses [Re: bonefish] #1592054
03/12/14 08:04 PM
03/12/14 08:04 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Yes.
I put a 4 barrel on mine and removed all unneeded ones.
Make sure emissions requirements are not needed.
Re: 88 YJ vac hoses [Re: moparborn] #1592055
03/12/14 09:17 PM
03/12/14 09:17 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
the carb motors i change to 2 barrel holley 500 cfm.jet down to 72 work good.you have to buy adaptor transdapt makes it
Re: 88 YJ vac hoses [Re: d-150] #1592056
03/12/14 09:50 PM
03/12/14 09:50 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
mine is a 4.2 inline six,i took off the slipper carb and put a carter2brl. on it.
