Speedo cable lube
#1592040
03/12/14 04:29 PM
03/12/14 04:29 PM
Posts: 1,487 STL
cdstl
STL
I have the dash apart and thought that it I should lube the speedometer cable.
What do you guys recommend for lube?
How should I do it, a few squirts from the top? Does the speedometer need any lubing?
72 E body.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Speedo cable lube
[Re: cdstl]
#1592044
03/12/14 09:15 PM
03/12/14 09:15 PM
Posts: 25 Orlando, FL
ChargerKnight66
Orlando, FL
I had my dash out to replace my voltage limiter so I thought the same thing...let me lube the speedo cable. Ever since then the speedometer needle bounces. I have since heard that the old cable lube was a bit waxy to dampen the cable. Not sure what is true, but now I wonder if the old adage; 'if it aint broke don't fix it' is true. Please post what you end up using and how it works out...I want my old smooth needle back.
