Page 1 of 4 1 2 3 4
Straight Through Type Mufflers On Street #1591922
03/12/14 02:30 PM
03/12/14 02:30 PM
Indiana
Y
YO7_A66 Online content OP
YO7_A66  Online Content OP
Y
Indiana
For those of you running straight through style mufflers on the street, do you have any resonance at cruising speeds?
If so, did you have to run a second muffler/resonator to try to get rid of the resonance or noise of the exhaust?
Is one of these mufflers per side too loud for a street car?
Note: I am planning on changing my exhaust to a straight through 2.5" system and I am considering using two straight through type mufflers in the rear. But I have read that this can be noisy for a street car and this can cause resonance due to the louder type of muffler. Some cases a second muffler/resonator might be required under the rear seat for the noise and resonance. If so, then I was looking at another straight through style muffler for this issue.
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591923
03/12/14 03:44 PM
03/12/14 03:44 PM
I ran a set of Magnaflow 14x7x 3 inch in and out on my pump gas street Duster, they where mounted behind the rear end between the 1/4 panel and rear sub frames, exited at the rear bumper I did have three inch pipes straight from the headers to the muffs, no resonators, nice sound at part throttle cruise No droning that I remember, they where a lot louder at WOT I raced that car a lot, it would pickup only .004 ET and .2MPH in the 1/8 mile by removing the exhaust from the headers back, probally the weight saving and not a reduction in back pressure making the gains My next street car will probally have a set of Ultaflow 3.5 inch muffs and pipes on it
Re: Straight Through Type Mufflers On Street [Re: Cab_Burge] #1591924
03/12/14 08:32 PM
03/12/14 08:32 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
my 440 coronet has headers, 3" pipes w/ h pipe and dynomax ultra flows
my 400 dart has headers 2.5" pipes w/ x pipe and pypes race pro mufflers
both mufflers are straight through and neither have any droning/resonance
Re: Straight Through Type Mufflers On Street [Re: 65rbdodge] #1591925
03/12/14 09:04 PM
03/12/14 09:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have the summit 3" exhaust and their 3" welded mufflers. They are straight thru, no drone they are just always loud. Probably best to get the Dynomax's and be done.
Coming soon!!!!
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591926
03/12/14 09:04 PM
03/12/14 09:04 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
On my 500" wedge with 3" exhaust, I run Dynomax straight thru mufflers ahead of the axle and cheap glass packs behind. The noise is acceptable for the street and it controls the drone while sounding a lot like these cars did in the 60s and 70s.
A lot of today's mufflers make our cars sound like rustangs and the like.
Master, again and still
Re: Straight Through Type Mufflers On Street [Re: DaveRS23] #1591927
03/13/14 08:34 AM
03/13/14 08:34 AM
Indiana
Y
Y
Indiana
Thanks for the replies.
I have been leaning towards putting in the largest diameter/length 2-1/2" (appx: 6" diameter x 18" body) straight through muffler that will fit beside the tank and then test the sound. Then if it is still too loud, then add another one under the seat (appx: 4" diameter x 14/18" body) to settle it down.
Thanks again.
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591928
03/13/14 11:20 AM
03/13/14 11:20 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Id go with Ultraflows under the seats and bullets along the tank.
Re: Straight Through Type Mufflers On Street [Re: AdamR] #1591929
03/13/14 11:43 AM
03/13/14 11:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
summit welded in car https://www.youtube.com/watch?v=zd66H_kkzJg
https://www.youtube.com/watch?v=FUOKfx8jPX8 outside car. Yes that's an SLP Z28 I had to spot him a second.
Re: Straight Through Type Mufflers On Street [Re: AdamR] #1591930
03/13/14 01:14 PM
03/13/14 01:14 PM
Indiana
Y
Y
Indiana
I am leaning towards the 6" diameter by 18" long bodied Magnaflow beside the tank. Then if required, I would look at the 4" diameter by 14"/18" long bodied Magnaflow as a resonator.
I attached one of the 6" verions for reference. I already measured and the 18" body should work beside the tank, it just depends on the tail pipe and I will buy it first before choosing the length of muffler. I want the longest muffler beside the tank that will fit.
Thanks to all.
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591931
03/13/14 06:31 PM
03/13/14 06:31 PM
USA
b54406barrel Offline
USA
I'll have to really dig but I think I still have a set of full size, 4" purple hornies I bought in 73. They'd be perfect!
Re: Straight Through Type Mufflers On Street [Re: b54406barrel] #1591932
03/13/14 06:41 PM
03/13/14 06:41 PM
Indiana
Y
Y
Indiana
I had never heard of those, so I had to look them up.
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591933
03/13/14 06:50 PM
03/13/14 06:50 PM
USA
USA
Those aren't the full size one's. Those are cadillac quiet compared to the first series. I had them on 69 bb camaro with a ZL-1 cam, off 2-1/8 tube cyclones. . It would rattle all the glassware around the counter at the local A&W.
Too many tickets so they had to come off.
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591934
03/13/14 08:11 PM
03/13/14 08:11 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I have just a set of 30 inch glass packs on my roadrunner and I like the way it sounds. Its a totally different tone and not too loud even with my long tube headers. Oh and I got rid of the drone at cruising speed too.
Re: Straight Through Type Mufflers On Street [Re: MidPenMopar] #1591935
03/13/14 08:11 PM
03/13/14 08:11 PM
MidPenMopar Offline
MidPenMopar  Offline
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591936
03/13/14 09:11 PM
03/13/14 09:11 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
On the straight thru mufflers both length and diameter matter when it comes to noise level. A muffler style will be much quieter than a similar length bullet. And stay quiet longer, too.
What they call bullet today used to be called a glass pack, right?
Re: Straight Through Type Mufflers On Street [Re: DaveRS23] #1591937
03/13/14 09:54 PM
03/13/14 09:54 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Pretty much
Re: Straight Through Type Mufflers On Street [Re: AdamR] #1591938
03/14/14 01:12 AM
03/14/14 01:12 AM
MidPenMopar Offline
MidPenMopar  Offline
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591939
03/14/14 03:11 AM
03/14/14 03:11 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
Initially I had 2.5" head pipes, UltraFlows and 2.25" tails. Way too loud. You couldn't hear someone next to you speak. Added an h-pipe and it was much quiter. Sounded like the old muscle cars. I changed headers and also changed to an x-pipe. Even quiter than the H, but definitely changed the tone. I like the latest setup best. I do have a video of this too if you want to hear it.
I'll bet you will need a crossover or multiple muffs to make it tolerable.
Re: Straight Through Type Mufflers On Street [Re: urdustd] #1591940
03/14/14 08:55 AM
03/14/14 08:55 AM
Indiana
Y
Y
Indiana
""I'll bet you will need a crossover or multiple muffs to make it tolerable.""
I thought of the largest straight through muffler in the rear (6 dia. x 14"/18"), then possibly the 4" dia x 18"/22" or so for a resonator, but I did not think of adding a possible crossover pipe. I am currently running each exhaust side seperately from each other. I will take some measurements to see what x-pipe might fit, just in case.
Re: Straight Through Type Mufflers On Street [Re: YO7_A66] #1591941
03/14/14 12:20 PM
03/14/14 12:20 PM
pa.
dan9 Offline
dan9  Offline
pa.
Has anyone tried the chambered exhaust? I am curious what they sound like for a 340. They come in different sizes and lengths.
Page 1 of 4 1 2 3 4
