300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP?
#1591828
03/12/14 10:03 AM
03/12/14 10:03 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
I'm trying to figure out my options here.
I'm told a 5.9L Magnum is basically a 300HP Magnum crate engine, as far as internals and specs go. Basically take a 5.9L Magnum from a truck, swap on an RPM and proper carb, and headers, and i'll have a 300HP (gross) HP engine. But what would the NET be?
Guess i'm asking, what do an RPM intake, proper carb and headers ADD to the 5.9L's net 240-245HP?
Talking just stock, pull-out engines here, BEFORE i start messing with heads, cams, compression, etc.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP?
[Re: Pale_Roader]
#1591829
03/12/14 11:43 AM
03/12/14 11:43 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Google the 2008 Hot Rod mag build.It's all there.
Leave the gun.......take the Cannoli's....Mike
[Re: Pale_Roader]
#1591830
03/13/14 01:46 AM
03/13/14 01:46 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
a bit, but not much without changing the cam.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: mike s]
#1591831
03/13/14 06:44 AM
03/13/14 06:44 AM
Pale_Roader
Swears too much
Swears too much
Not really... i've seen it many times before and it just tells me what i already know. I'm curious what kind ov NET HP figures that stock engine (w RPM, carb and headers) would make behind a manual transmission.
I'm guessing that the as installed NET HP would be considerably lower than the rated 300 engine dyno HP.
Or how about REAR WHEEL HP figures for the 5.9L Magnum? Dont suppose anyone here has chassis-dyno'd a truck? or a car with a swapped 5.9L?
[Re: jbc426]
#1591832
03/13/14 06:45 AM
03/13/14 06:45 AM
Pale_Roader
Swears too much
Swears too much
I could do the math myself, but being smallblock-impaired, i have NOOO idea what headers and an RPM intake add over the stock manifolds and beer barrel.
[Re: MarkZ]
#1591839
03/14/14 07:03 AM
03/14/14 07:03 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
[quote
I don't know what accessories eat up, but for drive line loss I see 15 and 18 percent tossed around a lot for manual and automatic respectively.
And that is being generous, I'd use a higher number.
Chrysler engineer I know took an engine he setup on a dyno and then transferred it over to a vehicle and it lost 18% with a manual trans.
Of course with this being said, dynos differ on what they register for output.
"I think its got a hemi"
[Re: MarkZ]
#1591840
03/14/14 08:08 AM
03/14/14 08:08 AM
Pale_Roader
Swears too much
Swears too much
All these articles are in gross/crank engine dyno horsepower. That means nothing to me. Maybe i've been playing with Mustangs too long, but i want to know what its doing in NET HP or RWHP.
Got it, so why does it have to be in the context of this particular motor and build? Parasitic loss is going to be the same percentage regardless of what motor is in front of it. Get the percentage based loss of the accessories you're looking to run and apply it to your gross number.
Now we're getting somewhere. I'd always used 17% loss from gross to net, which was based off no small amount ov math i did on the subject waaaaaaay back. Problem is, for the life ov me i cant remember how i came about those numbers, so i'm hesitant to use that here. I DO remember that in 1971, the Hemi made 425 gross HP and 350 net (about 17%). Thats not where my math came from though, but an interesting tidbit nonetheless. In fact, playing with the gross to net calcs in 1971 (the only year they rated with both methods) it typically comes out around 17%.
To keep things simple here too, i'm always talking about a stick car, with no accessories like power steering, AC, etc. Just the necessary stuff like alt, one pulley, etc.
What i'm doing here, is not so much building a bench engine, more just trying to figure out how these engines rate next to other modern engines. Still trying to figure out which way to go with the powerplant. Hard to compare a 300HP gross engine to a different 300HP net engine, and so on. I understand the 245 rating was a product ov crappy timing and tune, and equally bogus manifolds and exhaust... so for my intentions it just wont do. None ov the engines i'm comparing it to use gross ratings.
[Re: Pale_Roader]
#1591842
03/14/14 10:04 AM
03/14/14 10:04 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Gross, net and RWHP are all different from each other, and add in the ever changing standards that are used in the industry to make such measurements and you will understand that these types of comparisons become completely meaningless.
Knowing the quality/performance potential of the current exhaust and induction system will have the largest influence on the hp change from one set-up to the other. Then call it what ever hp gain that makes you happy
[Re: dogdays]
#1591844
03/14/14 03:31 PM
03/14/14 03:31 PM
mike s
Mi,U.S.A.
All Magnum engines were tested and rated w/accessories,water pump and alt working.Losses are not the same as the 60's.Bracketry, pumps belts,alt itself are all less drag.Engines were off the line everyday engines once production was started.Yes they may have had a different part or 3 but that was only to test new parts.BTW tested with the exact exh back pressure as the vehicle.
Where do you guys get this misinformation you are posting?
[Re: mike s]
#1591845
03/14/14 03:39 PM
03/14/14 03:39 PM
Posts: 189 Wisconsin,USA
Bzzzz
Wisconsin,USA
Maybe HotrodDave will chime in too! he messes with magnums quite a bit.. here is a good source too www.magnumswap.com
2005 Dodge 1500 Slt Hemi 2008 Chrysler PT cruiser 1984 Dodge D250 1978 Dodge D100 Adventurer 1964 Meyers Manx Dunebuggy
[Re: mike s]
#1591846
03/14/14 06:44 PM
03/14/14 06:44 PM
dogdays
So I said "with all accessories and I believe exhaust systems" how is that different than what you said?
There were, however, a lot of misconceptions starting with the OP.
R.
