Worth keeping original master cylinder? #159109
11/30/08 01:06 PM
11/30/08 01:06 PM
Gator73 Offline OP
Gator73  Offline OP
I recently replaced the original brake master cylinder on my 69 Coronet R/T with a remanufactured unit after it had been determined by my local brake shop that the original was too pitted inside and could not be rebuilt (at least by them anyway). Should a person keep an original part like a brake master cylinder or just turn it in for the core? I realize that if its junk its junk, but maybe there are other brake rebuilders that could save the unit. Just wondering before I chuck it. Thanks
Re: Worth keeping original master cylinder? [Re: Gator73] #159110
11/30/08 01:19 PM
11/30/08 01:19 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If it is indeed the correct original one for the car, you could always have it stainless steel-sleeved and use it again to be matching and all..
Re: Worth keeping original master cylinder? [Re: OzHemi] #159111
11/30/08 01:30 PM
11/30/08 01:30 PM
Gator73 Offline OP
Gator73  Offline OP
It is a relatively low mileage car that has been off the road since about '72. I am pretty sure it has to be the original master cylinder. Thanks for the info Oz. I guess anything can be rebuilt if you spend the money and can find someone to do it.
Re: Worth keeping original master cylinder? [Re: Gator73] #159112
11/30/08 01:58 PM
11/30/08 01:58 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
There was a thread a little while back about who does the sleeving I just can't remember off hand who it was...but a great way to go if you want to keep it correct. If it's just a 'driver' car, you can just use the parts store rebuild on it and keep the original one boxed away for now
Re: Worth keeping original master cylinder? [Re: OzHemi] #159113
11/30/08 04:41 PM
11/30/08 04:41 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Whitepost restoration in Virginia does the sleeving.
