Re: axle width needed
[Re: moparjim87]
#1591106
03/10/14 08:26 PM
03/10/14 08:26 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I can offer this, the 96 and earlier Dakota used a narrower rear diff than the 97 up. The 97 up was about 4" wider at the hubface.
The 98-2003 Durango uses the same rear diff as the 97-2004 Dakota in the reading I have found.
I found much of this on Dakota forums while searching for measurements to use to determine which of the B body 8-3/4 would fit best.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1591111
03/11/14 11:17 PM
03/11/14 11:17 PM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
Does your Dakota have the 5 lug wheels or the 6 lug wheels? 6 lug wheels will limit what you can swap, unless your going to deal with changing stuff, a 91 and newer Dakota, and all Durango's will have 6 bolt wheels, and there are no 8 3/4 axles that had 6 bolt wheels. Gene
I have a 66 B body 8-3/4 under my Dakota, with 6 lug axles. Wasn't hard to get them. All the original brakes, and drums, etc bolt right on.
What axles did you use?
[Re: poorboy]
#1591112
03/12/14 12:46 AM
03/12/14 12:46 AM
hp383
State of Confusion
Bought a set from DoctorDiff
