axle width needed #1591105
03/10/14 04:44 PM
03/10/14 04:44 PM
Indiana, PA
moparjim87 Offline OP
Indiana, PA
Im trying to see if a first gen durango 9.25 will bolt in a 2wd first gen dakota. Ive looked in fsm's and no measurements are given. Could somebody that has a durango measure spring perch width and possibly post it? Thanks in advance.
Re: axle width needed [Re: moparjim87] #1591106
03/10/14 08:26 PM
03/10/14 08:26 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I can offer this, the 96 and earlier Dakota used a narrower rear diff than the 97 up. The 97 up was about 4" wider at the hubface.
The 98-2003 Durango uses the same rear diff as the 97-2004 Dakota in the reading I have found.
I found much of this on Dakota forums while searching for measurements to use to determine which of the B body 8-3/4 would fit best.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: axle width needed [Re: hp383] #1591107
03/10/14 08:53 PM
03/10/14 08:53 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
My 2k 2wd axle was longer on the drivers side. Some are centered like 4wd.
Re: axle width needed [Re: hp383] #1591108
03/10/14 10:57 PM
03/10/14 10:57 PM
Indiana, PA
Indiana, PA
Thanks, looks like I'll be figuring an 8.75 in my plans then.
Re: axle width needed [Re: moparjim87] #1591109
03/10/14 11:20 PM
03/10/14 11:20 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Does your Dakota have the 5 lug wheels or the 6 lug wheels? 6 lug wheels will limit what you can swap, unless your going to deal with changing stuff, a 91 and newer Dakota, and all Durango's will have 6 bolt wheels, and there are no 8 3/4 axles that had 6 bolt wheels. Gene
Re: axle width needed [Re: poorboy] #1591110
03/11/14 02:57 AM
03/11/14 02:57 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
I have a 66 B body 8-3/4 under my Dakota, with 6 lug axles. Wasn't hard to get them. All the original brakes, and drums, etc bolt right on.
Re: axle width needed [Re: hp383] #1591111
03/11/14 11:17 PM
03/11/14 11:17 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What axles did you use?
Re: axle width needed [Re: poorboy] #1591112
03/12/14 12:46 AM
03/12/14 12:46 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Bought a set from DoctorDiff
