Re: MP Hemi pistons... Need bore clearance / ring gap specs
[Re: WarEagle1]
#1590970
03/11/14 04:06 PM
03/11/14 04:06 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Last time I rebuilt an engine, I thought the ring gaps and clearences were with the ring instructions. Did rings come with pistons? If anything, back to the top for you.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1590971
03/11/14 06:32 PM
03/11/14 06:32 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Ring gaps would probably be standard but you want to know for a fact on the piston clearance and where that particular piston wants to be measured. You will probably have to call Ma Mopar on that.
2011 Drag Pak Challenger
[Re: WarEagle1]
#1590973
03/11/14 07:24 PM
03/11/14 07:24 PM
Posts: 46 North
Dodgenu
North
I bought a set of P5007075 forged 10.5:1 Hemi pistons (4.500 bore / 3.750 stroke) through Chrysler several years ago. They came individually boxed and had zero paperwork with them. I need the recommended bore clearance and top & 2nd ring gaps (moly ductile iron top ring) for these. Can anyone advise? This is a normally aspirated, premium pump gas motor w/ aluminum heads.
Total seal file fit rings recommend bore x .0045.They also recommend opening the second ring .004 larger than the top, So yours would be .020 top ring and .024 second ring.
[Re: DAYTONA540]
#1590974
03/11/14 07:30 PM
03/11/14 07:30 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
P/W clearence .0045/.005 measured 1.300" below bottom of oil ring land. Ring end gap.Top ring-boreX .0045 2nd ring-boreX .0035 oil ring rail,min. .015 These are for N/A street,strip,and circle applications.
