MP Hemi pistons... Need bore clearance / ring gap specs #1590969
03/10/14 02:56 PM
03/10/14 02:56 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
I bought a set of P5007075 forged 10.5:1 Hemi pistons (4.500 bore / 3.750 stroke) through Chrysler several years ago. They came individually boxed and had zero paperwork with them.
I need the recommended bore clearance and top & 2nd ring gaps (moly ductile iron top ring) for these. Can anyone advise?
This is a normally aspirated, premium pump gas motor w/ aluminum heads.
Re: MP Hemi pistons... Need bore clearance / ring gap specs [Re: WarEagle1] #1590970
03/11/14 04:06 PM
03/11/14 04:06 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Last time I rebuilt an engine, I thought the ring gaps and clearences were with the ring instructions. Did rings come with pistons? If anything, back to the top for you.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: MP Hemi pistons... Need bore clearance / ring gap specs [Re: RoadRunner] #1590971
03/11/14 06:32 PM
03/11/14 06:32 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Ring gaps would probably be standard but you want to know for a fact on the piston clearance and where that particular piston wants to be measured. You will probably have to call Ma Mopar on that.
2011 Drag Pak Challenger
Re: MP Hemi pistons... Need bore clearance / ring gap specs [Re: rickseeman] #1590972
03/11/14 06:57 PM
03/11/14 06:57 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
Call Weisco that's who made all those pistons for mopar. Ring clearances come with your rings in the box and are different by manufacture not much but some. Hope this helps.
Re: MP Hemi pistons... Need bore clearance / ring gap specs [Re: WarEagle1] #1590973
03/11/14 07:24 PM
03/11/14 07:24 PM
North
Dodgenu Offline
Dodgenu  Offline
North
Total seal file fit rings recommend bore x .0045.They also recommend opening the second ring .004 larger than the top, So yours would be .020 top ring and .024 second ring.
Re: MP Hemi pistons... Need bore clearance / ring gap specs [Re: DAYTONA540] #1590974
03/11/14 07:30 PM
03/11/14 07:30 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
P/W clearence .0045/.005 measured 1.300" below bottom of oil ring land.
Ring end gap.Top ring-boreX .0045
2nd ring-boreX .0035
oil ring rail,min. .015
These are for N/A street,strip,and circle applications.
