sticking throttle cable
#159087
11/30/08 01:45 AM
11/30/08 01:45 AM
Posts: 4,179 California
mickm
California
been having trouble with this for a while. cable sticks when i let off the gas slowly, during normal driving. sticks a couple hundred rpm above idle. if i lift the gas pedal from behind, the idle drops down to normal.
but when i adjust the cable in the bracket at the manifold, it sometimes sticks worse, and will stay at 1500, 2000 rpm, until i lift the gas pedal.
the linkage at the carburetors works freely, and the cable works freely when not attached, so i'm assuming that under the load of the carb springs it is binding slightly.
it is a replacement cable for a hemi, and i have a stock reproduction bracket, so it is in roughly the same place as stock.
is there a way to lube these cables? i can't figure out anything else at this point. if i move the cable far enough forward in the mounting bracket that it doesn't stick, then i can't get WOT.
any thoughts????
Re: sticking throttle cable
[Re: mickm]
#159089
11/30/08 11:48 AM
11/30/08 11:48 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Depending on the age of the carb it could be a worn throttle shaft.
I have had that problem on numerous carbs.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: mickm]
#159093
11/30/08 01:28 PM
11/30/08 01:28 PM
Rug_Trucker
Slop in the throttle shaft will cause sticking. They usually don't stick with the cable disconnected.
If you readd think it is the cable there was a tool sold by JC Whitney for lubing cables. Maybe a motorcycle shop has something?
