Tire sise ???? #1590824
03/10/14 01:04 AM
03/10/14 01:04 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
If i go from a 14x32x15 slick to a 14x31x15 slick will i see any difference on the time slip or rpm?
Re: Tire sise ???? [Re: bobs69] #1590825
03/10/14 01:13 AM
03/10/14 01:13 AM
If i go from a 14x32x15 slick to a 13x32x15 slick will i see any difference on the time slip or rpm?
You really need to know thw actual circumfernces of both tires, there are a bunch of different size (circumference)14x32x15 out there Probally the ame thing on the 13x32x15 I've seen 14x32x15 advertised from 101 inches circumference to 104 inches
Re: Tire sise ???? [Re: bobs69] #1590826
03/10/14 01:15 AM
03/10/14 01:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You might see a slight increase in the ET and MPH due
to less drag and frontal area of the slick..... but
dont count on much if any
