Re: 16 volt battery, anybody know how to test?
[Re: camastomcat]
#1590788
03/10/14 04:48 AM
03/10/14 04:48 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
How old are they? How are you charging them, fast or slow? If they don't have much reserve capacity thier probally no good I would try hooking up a small light bulb to one of them and so it illuminates and run the battery down so it reads below 12 or 13 volts and then try charging it up very slowly at 1 to 3 amps for 4 or 5 days If that doesn't work you probally need another new battery. BTW are they lead acid batterys or some other newer higher technology like NiCad or AGM If there not lead acid plates don't try my method on your batterys I don't know how to properly charge the newer style batterys, yet
[Re: Cab_Burge]
#1590789
03/10/14 10:32 AM
03/10/14 10:32 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I found this out the hard way,if you don't keep a Battery maintainer on the 16 volt battery at all times when not racing,they don't last more than one season at best.The people at Rock battery will tell you this as well.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: pittsburghracer]
#1590792
03/10/14 01:55 PM
03/10/14 01:55 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I just couldn't get racing life out of a 16 volt battery and was always afraid it would leave me down at the wrong time so I switched back to a 12 volt battery. My Daytona ran 8.60's with the 16 volt and 8.60's with the 12 volt Sears platinum that came with a free replacement 5 year guarantee. 2 years later I started running an alternator again an I swear I will never run a race car without one again. Looking at the racepak graph is enough evidence for me. Sometimes we out-trick ourselves and make this sport harder than it has to be.
I really haven't had any problems with the 16V system for 7 years and like the way it turns the starter over with 16.3-1 compression. I would need to buy another alternator too, as I have a 16V one. This has been one of the few, but it has me thinking. Nobody really knows a lot about them.
#1590796
03/10/14 04:54 PM
03/10/14 04:54 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
16 volt batteries work great, up until they don't From my experience when they go they go quickly. Still would not run anything else in my car. Have had good luck with XS stuff over the years. But they do need to be maintained and charged. If not they live a very short life span. I run an alternator and use the charger between rounds to make sure. Also have it on a charger between races. It has a float mode and works great.
[Re: camastomcat]
#1590797
03/10/14 07:43 PM
03/10/14 07:43 PM
Posts: 4,210 New York
polyspheric
New York
I've heard bad things about 16 volt lead/acid batteries, but can't figure out what (except poor maintenance or quality control). All lead/acid batteries are just a group of individual cells which produce 2.1 volts each (which is the Pb + H2SO4 equation). Nominal 6 volt has 3 cells = 6.3 volts Nominal 12 volt has 6 cells = 12.6 volts Nominal 16 volt has 8 cells = 16.8 volts If any of these tests lower than shown (the extra .1 per cell) when fully charged it's toast. Important: other chemical types produce different voltage per cell!
Boffin Emeritus
[Re: camastomcat]
#1590799
03/10/14 08:19 PM
03/10/14 08:19 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Mine were the Turbo Start.
If you had 2 in parallel and they weren't on a turbo start battery tender over the winter, they are probably shot. When 1 goes, the other is right behind it, it you ran them together. If they are losing volts quick and cranking them I hard after a few starts, toss em. You can also try using isolating 1 at a time and see which one is bad.
[Re: camastomcat]
#1590801
03/10/14 09:16 PM
03/10/14 09:16 PM
Sammy
Wind Gap,Pa.
I actually never ran them together, but tried them both individually, and as soon as I hooked up the racepak, delay box, light dial board, digital 7, they went from 16.8 to 14.2.
I take it no alternator? Run it till you get it to temperature, turn it off and restart it. If it doesn't crank hard, they are toast. Keep us posted. I've been down this road before with them. Are you running the light weight turbo starts or regular ones?
[Re: Sammy]
#1590802
03/10/14 09:18 PM
03/10/14 09:18 PM
Al_Alguire
Las Vegas
They are likely toast. I had similar issues with the TurboStarts I used to run. One will definitely kill the other.
