Tech help needed... #159062
11/30/08 12:01 AM
11/30/08 12:01 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
Tech help needed...never worked on anything this new...engine has a dead miss and check engine light is on...took it down to the local Autozone and they ran the codes...says #3 cyl is mis-firing...where do I go from here? Is it computer, plugs, wires, coil? All the sales reps wanted to do was bad mouth that it was a Dodge...by the way it is a 5.7 Hemi and has 70,000+ miles...thanks in advance...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Tech help needed... [Re: RapidusMaximus] #159063
11/30/08 12:42 AM
11/30/08 12:42 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
To start I would pull the coil off for that cylinder (easy)and look for burn marks on it. If thats ok pull the plugs and have a look at them.Does it make any noise? When was the last time it had a tune up?
Re: Tech help needed... [Re: 10sec440] #159064
11/30/08 01:02 AM
11/30/08 01:02 AM
Weatherford, Texas
Weatherford, Texas
It isn't making any noise...I haven't taken anything apart yet...I bought the truck with 40,000 miles on it and haven't done anything but keep the oil changed...what's involved in a tune up? (sorry for the ignorant questions just never touched anything controlled by a computer)
1968 Plymouth GTX
Re: Tech help needed... [Re: RapidusMaximus] #159065
11/30/08 01:06 AM
11/30/08 01:06 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Valve springs break alot possibly with out making much noise.
Re: Tech help needed... [Re: SALEM1912] #159066
11/30/08 01:12 AM
11/30/08 01:12 AM
Weatherford, Texas
Weatherford, Texas
I sure hope it's not a broken valvespring...but you're the second person to suggest that...
1968 Plymouth GTX
Re: Tech help needed... [Re: RapidusMaximus] #159067
11/30/08 07:33 AM
11/30/08 07:33 AM
Jupiter, FL
P
Pistol_Grip_GTX Offline
super gas
super gas
P
Jupiter, FL
I would start with a tune up plugs & wires @ 70k it's about time for it.
Trevor
