bronze gear #1590539
03/09/14 07:26 PM
03/09/14 07:26 PM
minonk, IL
mopwer1 Offline OP
mopwer1  Offline OP
minonk, IL
How often should I change the bronze distributor gear? I have a 500" stroker with a hydraulic roller cam.
Re: bronze gear [Re: mopwer1] #1590540
03/09/14 08:57 PM
03/09/14 08:57 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
It depends on how many miles you drive. I put maybe 2000 miles on my car during the summer. I pull the gear every winter and look it over. Although it has never looked really worn I almost always replace it.
Re: bronze gear [Re: mopwer1] #1590541
03/09/14 10:00 PM
03/09/14 10:00 PM
Is the cam a steel billet roller core or a cast core like the OEM cams? If steel core cam and oil pump drive gear on it look at the bronze gear very carefully, there are good gears that last forever and there are others that don't
Re: bronze gear [Re: TooMany62s] #1590542
03/10/14 01:43 PM
03/10/14 01:43 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Mine only wears under the bronze gear were it meets up whit the bushing for the shaft and i swapt mine out now after two summers of driving it ! The push rod for the fuel pump whas looking like new on the bronze tip (No Wear at al) so i put that in again. I should metion that i run a std mellings oil pump in my engine so if you have a HV pump there probably is more wear on yours
Re: bronze gear [Re: Mopar Guy] #1590543
03/15/14 05:09 PM
03/15/14 05:09 PM
minonk, IL
mopwer1 Offline OP
mopwer1  Offline OP
minonk, IL
Where do you guys find the best price for the bronze gears? Thanks for the info
Re: bronze gear [Re: mopwer1] #1590544
03/15/14 06:46 PM
03/15/14 06:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This is such an easy problem to solve !
The reason either wears is because they are similar netals - both being bronze. Its a law of physics that two similar metals in a friction situation will cause one or both surfaces to wear.
So to solve the problem you put a thin steel shim between the two and kiss the problem goodbye.
Now the thinnest shim I've found is a torrington bearing thrust washer that is .030" thick so I have the bottom shoulder on the gear taken off (approx. .030) on a lathe.
Re: bronze gear [Re: mopwer1] #1590545
03/15/14 07:33 PM
03/15/14 07:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My small block one from Milidon has been on back-order. Says it MAY ship at the end of March. Are the gears on the big block and small block the same? If so I may have to switch some gears.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: bronze gear [Re: pittsburghracer] #1590546
03/16/14 12:15 AM
03/16/14 12:15 AM
BB distributors gears are a lot different than SB are, sorry
Re: bronze gear [Re: Cab_Burge] #1590547
03/16/14 01:15 AM
03/16/14 01:15 AM
PA.
"Little"John
"Little"John
PA.
BB idistributors gears are a lot different than SB are, sorry
Thanks cab. I was going to check one out today but didn't get a chance.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
