ceramic coated headers #1590521
03/09/14 06:33 PM
03/09/14 06:33 PM
San Antonio,TX
440W8 Duster Offline OP
San Antonio,TX
Is there anything that can clean them with oil stains on them.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: ceramic coated headers [Re: 440W8 Duster] #1590522
03/09/14 06:58 PM
03/09/14 06:58 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Easy-off oven cleaner work for me.
Re: ceramic coated headers [Re: rickraw] #1590523
03/09/14 07:09 PM
03/09/14 07:09 PM
San Antonio,TX
San Antonio,TX
Do I spray it on them then wipe off or do I get them hot then rub off?
70 Duster W8 motor.
@3170 lbs.
Re: ceramic coated headers [Re: 440W8 Duster] #1590524
03/09/14 07:19 PM
03/09/14 07:19 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Cold. Try a small spot first to see if it doesn't harm the finish. If it doesn't, let the stain soak for a while & wash off.
Re: ceramic coated headers [Re: rickraw] #1590525
03/09/14 07:25 PM
03/09/14 07:25 PM
San Antonio,TX
San Antonio,TX
any certain type of oven cleaner.
70 Duster W8 motor.
@3170 lbs.
Re: ceramic coated headers [Re: 440W8 Duster] #1590526
03/09/14 08:20 PM
03/09/14 08:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
EZ off is what took the oil that exited our W5 mill onto our TTI's. Worked like a champ!
Re: ceramic coated headers [Re: J_BODY] #1590527
03/09/14 08:41 PM
03/09/14 08:41 PM
Va Usa
beecrazy Offline
beecrazy  Offline
Va Usa
Mothers Mag cleaner ! Works awesome!
Kevin
Re: ceramic coated headers [Re: beecrazy] #1590528
03/09/14 10:04 PM
03/09/14 10:04 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
orange citrus cleaner. can find it at the dollar store. used in the kitchen as a grease cleaner. spray it on and scrub it with a scotchbrite pad then wipe off with a clean rag. makes them look new again.
Re: ceramic coated headers [Re: mopar dave] #1590529
03/09/14 11:43 PM
03/09/14 11:43 PM
San Antonio,TX
San Antonio,TX
OK Thanks for the help!
70 Duster W8 motor.
@3170 lbs.
