What and how to build an engine on a low budget with hp *DELETED* *DELETED* #1590497
03/09/14 04:34 PM
03/09/14 04:34 PM
Charlotte County, Florida
Floridamtbiker99 Offline OP
Post deleted by Floridamtbiker99
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590498
03/09/14 04:52 PM
03/09/14 04:52 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Do a Magnum V8 with a carb (you can make 300 horse cheap)
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590499
03/09/14 04:53 PM
03/09/14 04:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
With your Dakota you would be best off going with a small block. You will save money on suspension and other changes that you would have to make going to a big block. A 360 with the right cam, pistons and carb will make a great daily driver with plenty of go fast for the strip. Plus you can use an OD trans for mileage.
Re: What and how to build an engine on a low budget with hp [Re: stumpy] #1590500
03/09/14 05:05 PM
03/09/14 05:05 PM
I am new to mopar, I was chevy guy. I like Mopar stuff better.
Always loved the Roadrunners, and CUDA, Challengers.
What is my transmission. It has overdrive.
What year of a 360 to get? LA or Mag engine type? Will it bolt up.
I rather have a carb, easier to do.
Motor mounts? are they different than the 3.9 v6 (based of a 318 LA engine).
thank you.
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590501
03/09/14 06:58 PM
03/09/14 06:58 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
360 Magnum engine swap would likely be the least expensive route?
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590502
03/09/14 07:25 PM
03/09/14 07:25 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
Mopar Action currently has an article in it about rebuilding a 360 Magnum on a budget. Also they did a Dakota v6 to v8 a couple of years ago, it might be worth the effort to check their website for the older articles
Re: What and how to build an engine on a low budget with hp [Re: Goat330] #1590503
03/10/14 12:28 AM
03/10/14 12:28 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Your trans should be an a500. Keep it, but rebuild it to take the HP. Find a magnum 360 if you can, magnum 318 if you can't. That's a 92+ for the 318 and I think the mag 360 came a year later? Or was it a year earlier?
Mopar used to sell a crate engine they called the 360ci/380hp. It was basically a truck 360 with a lumpy cam, 4bbl intake. I remember one of the mopar mags did a dyno test on one and squeezed out just shy of 400 hp. That engine came with too much cam to get 22mpg on the highway though. Hell, even a stock cam mag 360 would hard pressed to get 22mpg in a 2wd dakota.
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590504
03/10/14 12:35 AM
03/10/14 12:35 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Try to find a 2000-2004 5.9, they have the best cam and make about 340Hp with a 750 vac. sec. carb and a good distributer curve.
Re: What and how to build an engine on a low budget with hp [Re: Dan Halen] #1590505
03/10/14 11:37 PM
03/10/14 11:37 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Another vote for the 5.9L Magnum swap. I did one years ago on a 87 Ram D150. With headers and a carb it was a solid 14 sec truck.
It may take a slight bit more work but you should seriously consider a late model 5.7L Hemi swap. With a 4 barrel carb intake and a aftermarket fuel injection. You will have a lighter 400hp engine that will get better mileage than any Magnum or old LA small block build.
Re: What and how to build an engine on a low budget with hp [Re: Magnum] #1590506
03/11/14 01:26 AM
03/11/14 01:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The gen3 Hemi makes a good swap, but I think it would be more expensive?
Re: What and how to build an engine on a low budget with hp [Re: 451Mopar] #1590507
03/11/14 01:57 AM
03/11/14 01:57 AM
Used Hemi s in Florida are going for $4000 to $5000 way out of my budget.
I would to have carb or aftermarket EFI system so I do not have to buy a Computer for it.
Thank you so far.
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590508
03/11/14 02:22 AM
03/11/14 02:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I got a 6.1L Hemi with the 5-speed Auto off E-Bay for $4,000. I want to use the EFI and such, so the computer needs reprogrammed, and I'm not sure about the electronics for the transmission?
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590509
03/11/14 11:03 AM
03/11/14 11:03 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The stock 5.2 magnum will run 14.0's in the 90's w/ nothing more than a computer change. AMHIK. For what you guys want I'd go w/ a cam upgrade, MP computer, headers (cheap and easy) and a nice free-flowing exhaust. That should get you well into the 13's if you want faster then bump up to a 5.9.
Coming soon!!!!
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590510
03/11/14 11:19 AM
03/11/14 11:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You need to get the 22mpg thing out of your head , the only truck capable of something like that has a 5.9 CUMMINS in it.
Is you V6 getting 22mpg ?
Re: What and how to build an engine on a low budget with hp [Re: JohnRR] #1590511
03/11/14 11:43 PM
03/11/14 11:43 PM
No my truck now gets 14 mpg. Why is so hard to get Horsepower and good mpg at the same time?
Re: What and how to build an engine on a low budget with hp [Re: Floridamtbiker99] #1590512
03/12/14 10:04 AM
03/12/14 10:04 AM
west palm beach, florida
modelmakerinc Offline
This forum Is great, However. since you are very new to mopars as your posts suggest, I would find a Mopar club and club members that are close to you so you avoid missteps and the confusion that comes with being a newbee
you kinda need a big (mopar) brother. go to this site http://www.flacarshows.com/ find the next show close to you and seek mopar owner guidance
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
